How To Raise Mustang II Front End Coil Overs ? - 460 Ford Forum
Old 05-18-2013, 10:13 PM
davvet2's Avatar
davvet2 davvet2 is offline
davvet2 Driving a Ford
Default How To Raise Mustang II Front End Coil Overs ?
The Mustang II front end in my car is so low that the headers are 2" from the ground.
I need to know the best way to raise the front end about 4 inches.
I tried cranking on the coil overs, but didn't get much results. I can't see any part numbers on the coils;
they were on the car when I bought it.
Suggestions?
Thanks,
Jim
Old 05-19-2013, 12:00 AM
xdute's Avatar
xdute xdute is offline
xdute First On Race Day
They wouldn't happen to be drop spindles would they?
Kevin
"I'm just going to swap the motor." What the! A rotisserie?
Old 05-19-2013, 09:33 AM
davvet2's Avatar
xdute,
I really don't know if they're dropped.
Old 05-19-2013, 10:18 AM
67cougar's Avatar
67cougar 67cougar is online now
67cougar First On Race Day
Did you try to adjust them with car on the ground? It should be adjusted with the car in air and make sure to oil the threads. But I don't think you will get 4''. I would look into the drop spindles too.
Old 05-19-2013, 11:07 PM
davvet2's Avatar
Thanks ...
Didn't know they were supposed to be adjusted in the air...
How do you keep track of the new settings, count the turns ?
Also, does releasing the spring pressure raise the heighth ? Counter clockwise?
Forgive me, I'm noob to all this.
Jim
Old 05-20-2013, 10:30 PM
2slow 2slow is offline
2slow Driving a Ford
4" , will have cut and lower frame rail.
or build a set of headers not as low.plus a taller front tire
  #7
Old 05-20-2013, 11:15 PM
davvet2's Avatar
I'm looking for a set of stock spindles now.
Cutting the frame rail is past my level of experience....
Thanks,
Jim
  #8
Old 05-21-2013, 07:55 AM
John Myrick's Avatar
John Myrick John Myrick is online now
John Myrick Driving a Ford
I have a set of never used spindles from my R&C motorsport kit
Regular height
Some people take themselves way too serious
  #9
Old 05-29-2013, 10:08 PM
twekd1 twekd1 is offline
twekd1 Driving a Ford
It looks like you have a lot of adjustment left, get 2 spanner wrenches and loosen the bottom coil over jam nut then with the car jacked up count turns raising the car. then tighten the jam. Put car on the ground drive around the block then on a level surface measure ride height on both sides adjust as needed. right to left.
