Help me make 1,000 hp N/A with P51 heads! - 460 Ford Forum
Go Back   460 Ford Forum > Tech Topics > Jon Kaase Racing Engines
Jon Kaase Racing Engines Jon Kaase is considered one of the best minds in the world of Big Block Fords and has created many parts to help enthusiasts with their 460 based projects. Gentlemen start your questions…
Photobucket
Old 05-24-2013, 10:04 AM
Big Block Notch Big Block Notch is offline
Big Block Notch First On Race Day
Default Help me make 1,000 hp N/A with P51 heads!
Like many people in the BBF community, I've been inspired by Blake's build My turbo build is progressing so slowly than I'm considering taking my N/A combo to the next level in the mean time to hold me over.
My ho-hum 532 make 796 hp on the dyno, and it runs 139 mph in a 3,330-pound Fox Mustang in 3,000-foot density altitude. The combo is a pretty standard pump gas (93 octane) setup: P51s ported to 420 cfm (with 2.250 valves), ported Victor intake, an 1150 Dominator, and a 278/290-at-.050 solid roller.
Before I stumbled upon Blake's build, I was toying with the idea of bumping up the compression to 15:1, putting bigger 2.300 valves in it, installing a vacuum pump, and upping the cam duration 5-10 degrees if necessary. It seems hard to believe this would add anywhere close to 200 hp, but Blake's build proves otherwise. I'd like to know what the smart guys out there think
Old 05-24-2013, 10:07 AM
I forgot to add that I think the big wild card here is the intake. What blows my mind about Blake's motor is that he's making 1,000 hp with a Victor intake! I'd upgrade to a Trick Flow intake if it offers a big boost in airflow, but I'm running a 5-inch cowl hood as it is with the Victor and the Dominator barely clears without an air cleaner.
Old 05-24-2013, 10:36 PM
BOSS 429's Avatar
BOSS 429 BOSS 429 is online now
BOSS 429 Driving a Ford
At what lift? what was the ehx flow? and what bore is your engine?
were these heads built for this engine?
RICH
CIRCLE (R) 815 712 8738
CLYINDER HEAD PORTING
COMPLETE ENGINES
632 557 532 598CI ETC
READY TO RUN OR DYNOED
Old 05-25-2013, 11:11 PM
Yes, heads were set up for this motor. Intake ports peaked at .700 lift. Current bore is 4.440. Exhaust ports flowed 260-265 cfm.
Old 05-26-2013, 09:02 PM
BOSS 429's Avatar
420 cfm@.700lift on a 4.440 bore ?????????????
RICH
COMPLETE ENGINES
Old 05-27-2013, 02:30 PM
Motor has a 4.440 bore. Not sure what size bore fixture the shop used when flowing the heads.
I'm 90% certain now that I'll be upgrading to the A460s, so it's a moot point. Thanks for your help.
  #7
Old 05-31-2013, 03:37 AM
TorinoStyle2 Driving a Ford
At "only" 532 cubic inches, it can certainly be done, but it would be easier with more displacement.
With the A460 heads, you will have great airflow, and race porting is going to be required.
Try a solid roller cam with about 288/296 @ .050" with .750/.750" lift, on a 112 lobe.
You're going to need about 16.5:1 compression, and at least an 1150 CFM Dominator carb, and 2.125 primary headers into 4" inch collectors. And spin it 7700-8000.
  #8
Old 06-01-2013, 07:18 PM
Lem Evans Lem Evans is offline
Lem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue Path
Blake's engine was 580" . The headers were 2-1/4" to 2-3/8" stepped.
B F Evans Race Parts
270-278-2376
  #9
Old 06-03-2013, 10:30 PM
IDT-572's Avatar
IDT-572 IDT-572 is offline
Forum Contributor
IDT-572 Driving a Ford
Thanks for the kind words, but my build had a ton of labor and thought in it and not your normal build.
You would be money ahead to go with the A heads if your after 1000 hp.
Blake
580 inch Ported P-51's
1003 hp @7200 810 tq @ 6100
86 Notch
29.5x13.5 Ladder Bar
1.200 60ft 5.41 @ 127.78 mph 8.51 @ 156 mph
200 shot 5.23 135 mph 1.13 60 ft.
5.23 135 mph on a 200 shot 1.13 on the rear tire.
  #10
Old 07-05-2013, 04:16 PM
richter69's Avatar
richter69 richter69 is offline
richter69 Driving a Ford
update...........
69 Grande'
P51 headed 563
3070#'s
5.15 @ 134.89
  #11
Old 07-05-2013, 04:20 PM
IDT-572's Avatar
Forum Contributor
Haven't ran it on the spray since the bash last year, it went 136 and some change there at a 5.41 spinning badly all the way to the stripe.
I have only been twice this year.
Blake
86 Notch
