C6 trans and 13 pennies shift improver - Page 2 - 460 Ford Forum
  #16
Old 05-31-2013, 02:24 PM
68montego's Avatar
68montego 68montego is offline
68montego First On Race Day
Yes I should have known lol. Too trusting I guess.
Old 05-31-2013, 03:15 PM
68xr7cat 68xr7cat is offline
68xr7cat Driving a Ford
You should have gone through the VB anyway. This will be a great time to add a drain plug to your oil pan too...
  #18
Old 05-31-2013, 03:32 PM
68montego's Avatar
Drain plug would be nice was thinking about that. I did go through the valvebody had to clean the mess out and put a new gasket in.
  #19
Old 05-31-2013, 07:55 PM
Glad to here you did go thought the VB, guess you saw reason why! FYI on the gasket, always put them up to the plate and make sure the gasket is not blocking any of the holes.
  #20
Old 05-31-2013, 08:49 PM
stuarta stuarta is offline
stuarta Driving a Ford
Tighten the banana plate last.
Wrench twister since 1957.
Journeyman in 1964.
Transmission builder since 1964.
  #21
Old 06-04-2013, 04:30 AM
stang4u2nv stang4u2nv is offline
stang4u2nv Driving a Ford
llright i cannot for my life understand the napkin picture.....can anyone here draw or post how to do the 16 penny mod? besides the napkin is there way for us newbies to do this mod? fellas you gotta lay it out in layman's terms for us...i can't seem to find it anywhere and i know the gurus in here know how to do it before i go and wrenck my mustang tranny..HELP PLEASE...if you guys don't want to post it here feel free to e-mail it to leon618348@aol.com...would be forever grateful. thanks
  #22
Old 06-04-2013, 05:06 AM
gregaust gregaust is online now
gregaust Driving a Ford
-Ok, let's start with the pennies . They go in the servo accumulator bore between the valve and cover . Stack them in to fill the cavity so as the end cover will fit back ok.
-The servo modulator valve beside it has a 1/4 steel ball on top between valve and cover to block its movement .
-To the cutback valve , a 1/4 steel ball under the valve to block any movement
-In that diagram looks like a 1/4 ball in the 2-1 schedule valve
- The main pressure spring is stretched a little to slightly raise line pressure .
- The hole in the seperator plate is drilled to 1/8", this is the hole beside where the check valve is in the channel casting.
  #23
Old 06-04-2013, 11:44 PM
allright sounds good but can you post pics of where these things go on the trans itself? maybe a spare valve body and pics would be amazing before i attempt this mod? i am considering this mod because my tranny is leaking from the gasket so might as well open it and do this while i am there. great info so far and would appreciate a few pics if not the n a pic of the C6 valve body and markings of where to make said changes...thanks a lot.
  #24
Old 06-05-2013, 02:28 PM
snotrocket snotrocket is offline
snotrocket First On Race Day
So are these mods and the ones mentioned in the other thread an option to use as aposed to a shift kit or to be used in conjunction with a kit? I think I could figure out how to do these from the napkin drawing but I'm wondering if I'm better of buying a shift kit if so what kits are better than others this will be a street driven truck with some track time
  #25
Old 06-06-2013, 06:01 AM
These mods are a form if shift improver very similar to a shift kit. They di near the same thing.
If you want a full kit the Transgo 67-2 is a nice choice
  #26
Old 06-06-2013, 03:02 PM
Default C6 VB
Journeyman in 1964.
