would you install a c4 behind a 700hp big block? - 460 Ford Forum
Old 05-30-2013, 12:01 AM
86GT32 86GT32 is offline
86GT32 First On Race Day
Default would you install a c4 behind a 700hp big block?
Been doing some reading, and come across a few guys arguing about glide or c4. Anyways, from what I've seen personally, most use a glide or c6 behind a big block, and it seems like a c4 couldn't stand up to that much horsepower for long before it destroys itself. I can see a c4 being used for a street application, and maybe some track use, but not a dedicated racecar. Am I wrong? Transmission Guru's please chime in.
Old 05-30-2013, 08:28 AM
bob460 bob460 is offline
bob460 First On Race Day
Can a C4 handle 700hp...YES.........But they need alot more Maintainace sooner.........By going with a C6, powerglide or even a turbo 400(i got one)....less $$$ and stronger, plus less maintainance.
But im no trans guru!!!
Old 05-30-2013, 04:16 PM
FAIRMONT MIKE FAIRMONT MIKE is offline
FAIRMONT MIKE First On Race Day
A heavily modified c4 would be high dollar and high up keep.
Pretty hard to beat a mostly stock c6 with the mods that Frank Merkle has outlined in the sticky's.... and low to none to keep up or worry about.
Old 05-30-2013, 07:09 PM
BOSS 429's Avatar
BOSS 429 BOSS 429 is online now
BOSS 429 Driving a Ford
THE BEST C4 lasts about 20 good passes then it slows about 100th or so,and get slower from there,this is w/trans brake and 800hp plus, the tq and the heat is what kills em.
round robin with lots of power better cool it very well
street big cooler,no brake? it will last a lot longer
so for your question about your deal,sure why not
but if you never want to worry,and when you want more power use a c6
RICH
CIRCLE (R) 815 712 8738
CLYINDER HEAD PORTING
COMPLETE ENGINES
632 557 532 598CI ETC
READY TO RUN OR DYNOED
Old 05-30-2013, 08:40 PM
460VEGA's Avatar
460VEGA 460VEGA is offline
460VEGA Driving a Ford
I love my c4, but I dont have 700 hp, yet.
74VEGA 466 C4 6.18@110,9.77@135.66 ON PUMP GAS
Old 05-30-2013, 09:06 PM
68montego's Avatar
68montego 68montego is offline
68montego First On Race Day
What about a stock c4 behind a stock 429? How would that handle?. I know it would put more to the ground than the power robbing c6.
  #7
Old 05-30-2013, 09:10 PM
BOSS 429's Avatar
rollerize the c6
RICH
COMPLETE ENGINES
  #8
Old 05-30-2013, 11:06 PM
68montego's Avatar
Gotcha.
  #9
Old 07-18-2013, 05:04 PM
xoliex xoliex is offline
xoliex First On Race Day
i currently use a tko600 and want to go to an automatic sometime. and i keep on going back and fourth between a ford c4 and a c6 or even a powerglide chevy.
i have a bbf c6 trans in the backyard that has been sitting in the elements. and my car is a OEM c6 car so thats a plus.
i will make 100% sure before i do the plunge.
  #10
Old 07-20-2013, 08:02 PM
torinojoe1971 torinojoe1971 is offline
torinojoe1971 Driving a Ford
Default C4
C4 cost more to build but will hold up to 700hp. I'm running 85 mustang with spray around 800hp going on 2nd season was torn done after 1st season no problem found. Ran car on street drove 30 miles to the track, 1st season was at track every week end. If trans is built right will hold up, c6 will be much cheaper to build. Joe
  #11
Old 07-20-2013, 10:08 PM
66prostreetFairlane's Avatar
66prostreetFairlane 66prostreetFairlane is offline
66prostreetFairlane First On Race Day
Garage
I have to agree the C6 is going to be much cheaper. If your will to pull the trans and freshen it up more often than the C6 you can use the advantage of power the C4 would give. Personally i have might mite from Dynamic Racing with trans brake and converter form them. I am pushing 950hp on pump on the street and will go to the track on the weekends. The trans is fully rolerized with many aftermarket upgrades and we also switched the gearing in it as to not have such a worthless 1st gear. I would give them a call they will tell you straight up if it will work or if they recommend something else.
66' Fairlane Prostreet
Blown boss 9 521ci
  #12
Old 07-20-2013, 10:22 PM
BOSS 429's Avatar
Post
how fast is this car?
RICH
COMPLETE ENGINES
  #13
Old 07-20-2013, 10:24 PM
BOSS 429's Avatar
how fast have you been with this c4?
RICH
COMPLETE ENGINES
  #14
Old 07-20-2013, 10:48 PM
yellowhorse7's Avatar
yellowhorse7 yellowhorse7 is offline
yellowhorse7 First On Race Day
^^^^^yep.
Tony
Circle R Performance
Team Z
Ultimate Converters
  #15
Old 07-21-2013, 09:52 AM
Garage
Rich i'm sure you know the answer to your questions and you're trying to prove your point. We both know the car ain't done and its gone 0 miles and 0 passes. I am with you that the C6 is less maintenance and cheaper, however we all know the c6 robs more power than the c4. If he is willing to pull it ever couple of weeks then thats up to him. Most want to put the trans in and forget about for a good part of the season. I personally have mine in with a mid plate and removable trans mount so its easy to pull mine out. Dynamic Racing did try some new parts and new things on my trans and im the geni pig on it.
Blown boss 9 521ci
Insurance
Date of Birth
Month Day Year
Privacy
