C4 questions - 460 Ford Forum
Old 06-05-2013, 08:21 AM
fordmonsta fordmonsta is offline
fordmonsta Driving a Ford
Send a message via Yahoo to fordmonsta
Default C4 questions
Im fixin to start building a c4 for my fairlane and was reading about some "thin" clutches for the forward clutch where can a fella get some also for the high clutch too I already have a c5 case to start with and ultra bell I've built many a c4 over the years but never much more than a stock rebuild this trans will be behind my 552
Old 06-12-2013, 09:13 AM
347galaxie's Avatar
347galaxie 347galaxie is offline
347galaxie Driving a Ford
broader performance
It aint braggin' if you back it up!!
Old 06-13-2013, 04:33 AM
gregaust gregaust is offline
gregaust Driving a Ford
Yes Broader do all you want or an Alto power pack. 6 in each pack will do nicely. What else you planning?
Old 06-18-2013, 03:17 PM
460Skywalker 460Skywalker is offline
460Skywalker Driving a Ford
Default clutches
Please if you are going to drag race, use thick steels in high drum and borg-warner clutches. The oil needs cuts in the clutches in high hp/torque to apply fast enough or they will burn up, YOU will have alot of heat in high so thin steels like to warp. Been there done that. My stock clutches of 5 did better then the smooth 6 clutches and talked to too many race c4 places and they agreed what i have found out, high fluid pressure is a must on a stroker around 240, five in high has been proven to be best with stock clutches in pro-trans transmissions. I done alot of expermenting with mine. Its the torque and rotating weight that kill third, Its the week link when you put them on the edge.
Insurance
Date of Birth
Month Day Year
Privacy
