C6 Lockup Issue.......... - 460 Ford Forum
Old 06-06-2013, 09:29 PM
Price5113 Price5113 is offline
Price5113 First On Race Day
Default C6 Lockup Issue..........
Well, after searching through this forum and not finding much about my C6's exact symptoms I thought I better ask for help on this one. This C6 has been working great since last fall when I rebuilt it until out of the blue I manually shift down into second and the 'lockup' happens. It seems 1st gear is affected as well. It does go into Drive, but theres no 1st gear to 2nd gear action at all, just lockup! I have adjusted the Hurst QTR Stick shift more than half a dozen times per there instructions and have dissconnected the shifter from the trans and manually moved the lever only to find the problem still exists! I changed out the valve body this afternoon with a "loaner" NEW TCI Streetfighter peice and readjusted the band but still the problem is there. The Servo piston is a Superior "R" copy, the trans is a 1975 vintage peice with STD replacement clutches, a #9 needle brg, and a TCI Streetfighter 11" converter. It baffles me that this happened all of a sudden with out any warning signs..........Any help on this would be great!
Old 06-06-2013, 10:55 PM
Frank Merkl's Avatar
Frank Merkl Frank Merkl is offline
Frank Merkl Driving a Ford
tear it down
Frank
Old 06-06-2013, 11:16 PM
stuarta stuarta is offline
stuarta Driving a Ford
Sounds like the clutch packs are seized.
Like Frank said "tear it down".
Wrench twister since 1957.
Journeyman in 1964.
Transmission builder since 1964.
Old 06-07-2013, 02:38 AM
TorinoStyle2 Driving a Ford
Mine likes to apply 1st and reverse at the same time. Its like Im standing on the brakes, but Im not!!
Old 06-07-2013, 07:15 AM
Default Thanks....
Thanks for the replys! I will be pulling the trans...................
Insurance
Date of Birth
Month Day Year
Privacy
