motor plate-waterpump ???? - 460 Ford Forum
Go Back   460 Ford Forum > Full Race Tech > General Race Tech
General Race Tech All other topics, such as Fuel Delivery, Ignition, Engine, Safety, Data Aquisition, Suspension, etc...
Old 03-28-2014, 06:48 PM
bigblockpaul bigblockpaul is offline
bigblockpaul Driving a Ford
Default motor plate-waterpump ????
iam putting a motorplate on my bbf in mustang.i run the Moroso elec waterpump do i use the plate behind the pump or put the motor plate up against timming cover then waterpump to motorplate??thanks.Paul
Old 03-28-2014, 10:10 PM
White Lightning's Avatar
White Lightning White Lightning is offline
White Lightning First On Race Day
The stock crank driven style water pump backing plate is not necessary when using an electric water pump. Bolt the front plate between the electric pump and the timing cover and you are done. I use silicone between the front plate and timing cover and between the pump and front plate. Some pumps come with an o ring on the mounting surface, I still use a small amount of silicone to insure a good seal because of plate movement. Hope that helps.
Rob
Rob Hawes-Anchorage Rod Works-Anchorage, Alaska
Old 03-29-2014, 09:40 PM
Anquia Anquia is offline
Anquia First On Race Day
try using aviation gasket sealer on the motor side gaskets. it comes in palastic small jar with a brush. that stuff will work for you. also use grade 8 bolts and tighten the pi&& out of them.
best affiliate programs
