getting airborn with heavy dana 60 and coils - 460 Ford Forum
Go Back   460 Ford Forum > Full Race Tech > 4x4's, Pullers, Crawlers and other HD rides
4x4's, Pullers, Crawlers and other HD rides We don't need no stinkin' asphalt!
Old 06-13-2013, 09:27 PM
jerad188's Avatar
jerad188 jerad188 is offline
jerad188 First On Race Day
Default getting airborn with heavy dana 60 and coils
Some of the bogs i run have higher humps in the middle and at the end of the run, slowing down not only bums out the crowd but it really ruins some good motivation when flyin through the mud. I have my dana 60 in my f150 with 9 inch coil springs, i do have limiter straps but should i run dual shocks to slow the rear end down when falling if the truck goes off the ground? the truck is a little springy as it is but when it slams down id like for my coils springs not to come flying out my fenderwell!
77 f150 short bed , 466 chipped at 6800 , comp 292 cam , 2800 stall c6, 5.13's/ 38.5's
Old 06-14-2013, 06:35 AM
kjett's Avatar
kjett kjett is offline
kjett Driving a Ford
Do you have bumpstops installed? If your truck is "springy" then your shocks aren't doing their job and you may want to invest a little money there to make sure compression and rebound is under control.
Old 06-14-2013, 08:37 AM
jerad188's Avatar
Oops no now that I think about it I never put bump stops on. My shocks are just the generic Rancho ones. If I put dual shocks on would it help noticeably
Old 06-14-2013, 09:15 AM
kjett's Avatar
Most of those generic shocks are set up with a 50/50 compression/rebound setting. To handle going airborn, you really need something with more valving control to get things right. I ran 90/10 drag shocks up front with the bumpstops and it worked really well on flat tracks but would jar me a little on the hard bumps.
Old 06-14-2013, 10:26 PM
Mud Freak's Avatar
Mud Freak Mud Freak is offline
Mud Freak Driving a Ford
I agree with Karl here, I run 90/10 front shocks as well, I've seen some pretty decent air time and it seems to soak it up pretty well with just a 4" BDS coil up front. The rear is AFCO 9" coil overs with a mono leaf, its a little bouncy but I'm workin on it still LOL
When in doubt, hold'er to the floor.......I'm usually in doubt.
http://www.youtube.com/user/mudfreak79
President of the P.C.O.R.A.
Old 06-15-2013, 09:06 AM
575ciBronco's Avatar
575ciBronco 575ciBronco is offline
575ciBronco First On Race Day
You want a soft spring and a stiff shock that is the key for getting air and having a nice landing.
Derrick
  #7
Old 06-16-2013, 09:18 PM
jerad188's Avatar
my springs are very soft for as big as they are, ill look into some other shocks, how do i know what i need? does the stiffness go by the weight of the vehicle or?
  #8
Old 06-16-2013, 09:43 PM
Try these been running them for years and never had any problems. They have 11/16 shaft and bump stops. Easy on the wallet too at only 44.00 and you can get any length you need with either a stud & eyelet or eyelet & eyelet.
http://broncograveyard.com/bronco/c-171
  #9
Old 06-18-2013, 08:03 PM
jerad188's Avatar
heres a question for you about bump stops, i have a set of rubber airbags that came out of an old f150, they go inside the coil springs, would those work as bump stops?? can only compress them so much insde the coil, could be a nice soft bump stop?
  #10
Old 06-18-2013, 09:00 PM
kjett's Avatar
You don't want to do that. Those air bags are meant to help load carrying capacity. They essentially increase the lb/square inch rating of the coil spring. Not what you want for a bump stop.
  #11
Old 06-18-2013, 09:15 PM
jerad188's Avatar
i understand that and it makes sense, but since my coil springs are probably twice as long as these air bags, by the time the airbag gets used it might be right where the bump stops will need to be anyway.... or should i just shut up and leave that idea alone haha..
i was just looking for a place to even put bump stops and i couldnt find any place that would look decent since i have a big lift on..
  #12
Old 09-09-2013, 05:13 AM
Danny Cabral's Avatar
Danny Cabral Danny Cabral is offline
Danny Cabral Driving a Ford
I was just looking for a place to even put bump stops and I couldn't find any place that would look decent since i have a big lift on...
Most good bumps stops for lifted trucks are custom fabricated.
Depending on how tall your coil springs are, these damper donuts
may be an option. Better than nothing, which will break stuff:
http://www.energysuspension.com/asse...on-catalog.pdf (page 13 - 2 1/4" tall, 3 9/16" dia.)
http://kspecracing.com/energy_suspen...r/i-99165.aspx
http://www.race-mart.com/Energy_Susp...E-9.9005R.html
http://www.summitracing.com/parts/ens-9-9005r
UPDATE: http://www.460ford.com/forum/showthr...89#post1269489
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, cold air induction, dual 3" exhaust/Magnaflow mufflers, 100HP progressive dry direct-port NOS, A/C, Lentech Strip Terminator wide-ratio AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim joint steering, Cage long radius arms, custom traction bars, 4" lift, 35" mud tires
  #13
Old 09-09-2013, 06:39 AM
jerad188's Avatar
How much travel should I allow my springs to have? There 9" lift coils
  #14
Old 09-09-2013, 07:11 AM
They're 9" lift coils.
Well then forget about using the above mentioned damper donuts.
I allow almost 3" compression (with my custom bump stop).
  #15
Old 09-09-2013, 07:50 AM
bsfarmer's Avatar
bsfarmer bsfarmer is offline
bsfarmer First On Race Day
Call the manufacturer about your spring rate first. You'd be surprised on how stiff those 9" coils really are. Go with a softer coil, higher quality shock, and look into air bumps. Might be more money for the air bumps but well worth it IMO.
My bronco isn't setup perfect for bogs or weight transfer, but I run a wild horses 4" coil in the front (which is one of the softest FSB coil on the market), and dual shocks in the front and I've caught some good air with it and it took it surprisingly well.
I would figure out the compressed length of your coil and set your bumpstops to that level. As far as travel you are only going to get what your free length minus compressed length of your coil. Spring rate will determine where right height will be at. The spring manufacturer will have all that info.
When Plan A doesn't work, you can always turn to Plan B!
