Pressure plate clamping force...how much is too much? - 460 Ford Forum
Old 06-20-2013, 09:21 PM
AlanCasida AlanCasida is offline
AlanCasida Driving a Ford
Default Pressure plate clamping force...how much is too much?
I am just about finished with the 521 DragWeek motor for my 66 Galaxie and I am undecided on what pressure plate to use. I have bought a 3200lb Mcleod diaphragm style unit but I am concerned it will still take two men and a boy to push the clutch pedal in. I had a 2300lb diaphragm type behind my 460 that worked just fine but I never ran it at the track. Is 3200lb overkill or do I need something like that to handle all that torque coupled with a 4400lb car? The transmission is a TKO600 5 spd.
Old 06-23-2013, 04:25 PM
bbstickstang's Avatar
bbstickstang bbstickstang is online now
bbstickstang Driving a Ford
Send a message via Yahoo to bbstickstang
Clamp pressure will depend on type of disc as well HP, weight,rear gear, 1st gear ratio and driving style.
3200 is a lot of pressure , but if your running a organic disc you may need that much with you combination.
If it is a truly street strip car you will have to compromise.
If you want something with a lightened pedal pressure you can go with a six paddle sintered bronze disc, it has a high coefficient and will hold with a lot less pressure than a organic disc, like around 1400# plate load,BUT is very aggressive and will chatter , but it will hold with slicks, HP and weight.
Next up would be the Sintered Iron single disc with a Long style PP that is adjustable both in Clamp(static) pressure and centrifugal counter weight. In a race application you can get down to 500# along with 10 -12 grams of counter weight and it will hold 600HP or more at 4000#(car weight) as long as its geared right.
You need some slip either from the clutch or tires with that TKO in order to keep from breaking it. IMHO............
6.15@112. 1.32/60' New best, 12-20-13 All Muscle and No Steroids!
69fb mustang ,509,nash 4+1,4.56 ,31x10.5 w ,3309 w/driver.
I get to feel the torque of a BBF 4 times an 1/8 and 5 times a 1/4.
www.classicgearjammers.org
Old 06-23-2013, 11:36 PM
Thanks for the input. You provided me with some very valuable information. I have similar concerns over the TKO also. I have not raced it and it was behind a mild 460PI before. I am contemplating putting the C6/Gearvendor back in it for DragWeek.
Insurance
Date of Birth
Month Day Year
Privacy
