My 1994 Mustang Index racing build - 460 Ford Forum
Old 06-29-2013, 03:51 PM
bigblok86ranger's Avatar
Super Moderator
Default My 1994 Mustang Index racing build
Posting a new thread with better pics...
This is getting the 528 out of my truck with some updates to the engine. Gonna be a small tire stock suspension deal hoping to get in the 8.60 index in GDRA and Byron Dragways Midwest Index Shootout.
Humble beginnings
Eric Millard
bigblok86gt@yahoo.com
528ci of N/A power
Circle R Racing Engines
Trick Chassis
Beloit,WI 53511
608-313-9197
http://www.trickchassis.com/
Old 06-29-2013, 03:56 PM
Super Moderator
Interior removed and through the floor subframe connectors getting installed.
Eric Millard
528ci of N/A power
Trick Chassis
Beloit,WI 53511
608-313-9197
Old 06-29-2013, 04:03 PM
Super Moderator
Ten point Competition Engineering cage install. Had to have a custom windshield bar made as the one that came with the kit didn't tuck tight enough to the roof.
Eric Millard
528ci of N/A power
Trick Chassis
Beloit,WI 53511
608-313-9197
Old 06-29-2013, 04:08 PM
Super Moderator
Hood trimmed and mocked up for hood scoop.
Stock dash gutted completely with switch panel and oil pressure and water temp gauges installed in the shell of the instrument cluster.
Also replaced factory column with something lighter (quick release installed)
Eric Millard
528ci of N/A power
Trick Chassis
Beloit,WI 53511
608-313-9197
Old 06-29-2013, 04:11 PM
Super Moderator
Shiny new swap pan with windage screen and baffles.
Engine mock begins.
Eric Millard
528ci of N/A power
Trick Chassis
Beloit,WI 53511
608-313-9197
Old 06-29-2013, 04:13 PM
Super Moderator
Woo Hoo got my 8.50 certification and the inspector said he liked the install.
Eric Millard
528ci of N/A power
Trick Chassis
Beloit,WI 53511
608-313-9197
  #7
Old 06-29-2013, 04:15 PM
Super Moderator
Brake adapter from UPR.
complete front suspension also from UPR.
Eric Millard
528ci of N/A power
Trick Chassis
Beloit,WI 53511
608-313-9197
  #8
Old 06-29-2013, 04:20 PM
Super Moderator
Vacuum pump fitting and hardware.
Eric Millard
528ci of N/A power
Trick Chassis
Beloit,WI 53511
608-313-9197
  #9
Old 06-29-2013, 04:24 PM
Super Moderator
And the magic piece to the stock suspension puzzle (LOL) great looking piece with adjustable upper and lower control arm brackets and double adjustable upper and lower control arms.
Eric Millard
528ci of N/A power
Trick Chassis
Beloit,WI 53511
608-313-9197
  #10
Old 06-29-2013, 04:28 PM
Super Moderator
Housing and control arms installed into the car.
Eric Millard
528ci of N/A power
Trick Chassis
Beloit,WI 53511
608-313-9197
  #11
Old 06-29-2013, 04:30 PM
Super Moderator
And the car sitting on the ground on its own weight with mock up 99% complete.
Eric Millard
528ci of N/A power
Trick Chassis
Beloit,WI 53511
608-313-9197
  #12
Old 06-29-2013, 07:31 PM
Mustang-Junky's Avatar
Mustang-Junky Mustang-Junky is offline
Mustang-Junky First On Race Day
Looking good. Lots of progress.
Jess
'90 mustang 545, Weiand tunnel ram, Predator carbs, c-4 with brake, 4800 stall UCC, 9" 4.10 gears, 390/45r 15 drag radials, ladder bars.
  #13
Old 06-30-2013, 10:27 AM
Lincoln1 Lincoln1 is offline
Lincoln1 First On Race Day
Dang your build is moving along. Looks good.
  #14
Old 06-30-2013, 12:01 PM
Super Moderator
Thank you! Still have a bunch to do, I muffed up some threads on a couple spark plugs that need to get fixed and broke an ear off one of the exhaust ports that needs to be welded so the heads are going to the machine shop next weekend to get that done and the intake is gonna get ported this go around and need to install the new pan on my engine (using a mock up block to get the engine set up in the car).
I still need to get a new front pump for the trans and a new trans brake valvebody, a center section and spool and pay for the gears and pinion yoke and get that set up, driveshaft. Then I need windows plumb brakelines install a seat and ignition box, buy and plumb a fuel system. Window net and parachute. Probably be end of August early September before will be able to start testing the car.
I am thinking probably get the suspension lined out and the car running good then put it up for the winter and get after it next year full season.
Eric Millard
528ci of N/A power
Trick Chassis
Beloit,WI 53511
608-313-9197
  #15
Old 07-10-2013, 10:25 PM
BOSS 429's Avatar
BOSS 429 BOSS 429 is offline
BOSS 429 Driving a Ford
LOOKS THE SAME AS WHEN I WAS THERE,
30 DAYS AGO
RICH
CIRCLE (R) 815 712 8738
CLYINDER HEAD PORTING
COMPLETE ENGINES
632 557 532 598CI ETC
READY TO RUN OR DYNOED
