C6 Servo Springs-whats the best choice? - 460 Ford Forum
Old 06-29-2013, 05:23 PM
rickfarm rickfarm is offline
rickfarm Driving a Ford
Default C6 Servo Springs-whats the best choice?
Regarding C6 servo springs: I have a choice of using an N code and a P code servo.
Now from what I understand, the P code has more surface apply area than the N...BUT the N code servo has a much stiffer but shorter yellow spring than the longer/softer orange spring in the P code.
I am looking for the best possible second gear shift out of this combination of parts. Am I correct in thinking I should use the stiff yellow spring from the N code servo in the P code??
Can someone please shed some logic on how these springs operate with regard to shift timing/etc.??
Old 07-02-2013, 02:02 PM
Frank Merkl's Avatar
Frank Merkl Frank Merkl is offline
Frank Merkl Driving a Ford
use any of the stock ford ones that have .136 dia. wire or thicker
Frank
Old 07-03-2013, 11:34 AM
Default yellow spring
thanks for the info Frank,
The shorter yellow spring that was originally with the N-code servo has .135/.140 wire diameter so I will use it with the P.
