Drag race transmission. C4 or TH400?? - 460 Ford Forum
Old 07-17-2013, 04:57 AM
TorinoStyle2 Driving a Ford
Default Drag race transmission. C4 or TH400??
3300# Torino, 472" with a little NOS and currently a C6. The C6 is not working for me, so I need to switch to a unit that will work.
I like the idea of a full built C4 because of the light weight of the unit as a whole, and the light weight rotating internals. But I hear too many negative comments about them in full race applications....and mostly from Ford guys!!
I also am considering a GM TH400 with a BBF bellhousing. I know this trans will take anything I can dish out, and if I have trouble with it at a race, there are usually several vendors on site that can rebuild, or repair it within minuites.
In any case, this will be a full rollerized, reverse manual unit with a transbrake.
What say you??
Old 07-17-2013, 09:52 AM
bob460 bob460 is offline
bob460 First On Race Day
What say you??
Talk to Frank Merkl about your C6, thats what i would do first.
The C4 will handle alot of power but it's high maintainance.
I have a turbo 400 built by Mike Ridings and converter also built by him(his on this site), No problems on the street so far, will be at the track later this year!!
Hope this helps.
Old 07-17-2013, 08:07 PM
Dragz79's Avatar
Dragz79 Dragz79 is offline
Dragz79 Driving a Ford
What kind of problems are you having with your c6? If you want to stick with a 3 speed, you have the one to handle the most power with the fewest mods. What is your c6 built like now? To change to any other trany means lots of coin! Scott
Give it all it's got and don't look back!!
Old 07-18-2013, 01:07 AM
It has a Frank Merkle reverse manual transbrake valvebody in it. When idling or cruising around the pits in 1st gear, it automatically applies reverse and the transmission goes into a "bind" and locks up the wheels.
I suspect some kind of internal leaking somewhere thats putting the pressurized fluid into the passages that apply reverse.
I pulled the valvebody out and thoroughly cleaned it and inspected it, but could see nothing wrong with it to the naked eye.
I placed a strait edge on both half's and they were both flat as can be.
I re-installed it, and torqued it in the correct pattern. Now I have to rev up the engine to get the car to move in any direction.
Im going to have to spend the coin for another different transmission, as I have already spent way too much on this one, only to have problem after problem.
I've had this unit gone thru several times (4 to be exact) at the cost of $650 each time, so theres no way Im doing it again.
Old 07-18-2013, 09:02 AM
stuarta stuarta is offline
stuarta Driving a Ford
Wink
It is not being done right then.
Wrench twister since 1957.
Journeyman in 1964.
Transmission builder since 1964.
Old 07-18-2013, 09:25 AM
68montego's Avatar
68montego 68montego is offline
68montego First On Race Day
I rebuilt my c6 by myself. First time ever rebuilding a transmission. Works flawlessly couldn't be happier. They are pretty simple even for a guy who knew nothing about transmissions. When mine reved up to go anywhere there was a lot of burnt clutches and clogged valvebody.
  #7
Old 07-18-2013, 10:43 AM
When I pulled the pan, it was full of thick black/grey gunk....probably clutch material. That is why I had to clean out the valvebody too.
I've done several C4's myself for mild performance apps., but I did'nt have the time to do my C6 because of work schedules.
  #8
Old 07-18-2013, 12:42 PM
Convertor, cooler and lines will have the same junk in them.
Journeyman in 1964.
  #9
Old 07-18-2013, 08:48 PM
460VEGA's Avatar
460VEGA 460VEGA is offline
460VEGA Driving a Ford
A good c4 would be fine on motor,but on the gas it might be iffy. I`ve had good life out of mine running high nines at 2800 lbs, but I don`t spray it.
74VEGA 466 C4 6.18@110,9.77@135.66 ON PUMP GAS
  #10
Old 07-19-2013, 03:51 AM
gregaust gregaust is offline
gregaust Driving a Ford
Something way wrong in the setup. Frank gives the whole setup , I'd be staying C6 and follow that.
  #11
Old 07-19-2013, 06:32 AM
^5.
Journeyman in 1964.
  #12
Old 07-19-2013, 07:42 AM
butterbean butterbean is offline
butterbean First On Race Day
Default trans talk
Hello Style2, I'm doing my first ford build and my first delimma was the trans problems that I herd about with the fords (being a chevy guy for ever) so I was going to do mine with a t-400 as well, but I was helping a guy at the track tune his Montego when he told me he was going to put a P/G in his car so as a racer for a long time I said why whenever you have a really good C-6 and his reply was that all the dragster guys are running P/G's my reply was they are 1800 lbs and you are 3600, anyway he done the swap and his car ran the same ET's to the number so I baught his C-6 w/brake and converter and it works perfact as good as any T-400 or P/G I ever owned so take it out and give it to someone that knows C-6 trannys first and don't give up! I would give you the name and number to the tranny guy but we live in sunny south Florida good luck friend and happy racing, Butterbean
  #13
Old 07-19-2013, 05:18 PM
torinojoe1971 torinojoe1971 is offline
torinojoe1971 Driving a Ford
Default c6
Talk to Frank, I would stay with the c6 and take it to someone who knows what there doing. Way cheaper to build c6. You could go c4 but its not cheap. I run a a c4 with all PA internals and trans brake love the trans 410w with 250 shoot running 9's in a 3200lb mustang, but I have with converter around $2500 into. C4 will work but it'll cost you. Make sure you flush the lines and cooler. Joe
  #14
Old 07-19-2013, 07:54 PM
Is a C6 cheaper than a TH400??....all the Chevy boys say no, but I have not done comparison shopping yet.
A TH400 has slightly lighter internal parts, right?? Plus it will take the big torque that a C4 wont, correct??
Im kinda leaning towards the TH400.
  #15
Old 07-19-2013, 08:22 PM
68montego's Avatar
You can rollerize the c6 with torrington bearings which reduces the internal drag and friction which results in it eating up hp. Also can modify and stick some E4OD parts in there which help even more. Dont know price comparison though.
Insurance
Date of Birth
Month Day Year
Privacy
