Automatic overdrive trans options for a 460 - 460 Ford Forum
Old 07-17-2013, 08:38 PM
junkyardjeff junkyardjeff is offline
junkyardjeff First On Race Day
Default Automatic overdrive trans options for a 460
I am thinking about going with a automatic overdrive in my 460 powered 1966 F250 in the future,it has 3.54 gears but would like to slow the motor down a little when going down the highway at 70 or above. What options do I have for a automatic overdrive that will hold up.
Old 07-17-2013, 09:08 PM
Dman64's Avatar
Dman64 Dman64 is offline
Dman64 First On Race Day
I put a 4R70w behind mine and love it, it works well but it can be pricey.
D
Sent from AutoGuide.com App
1964 F100 466 zero decked fuelie 7cc dish pistons, with RHP 2.11 1.65 budget D3 heads, Voodoo cam 219/227, rpm intake, Holley Terminator EFI, MSD Ignition, MSD FORD TFI Distrbutor, 4R70W Trans with Baumann Re-cal kit, US Shift electronic Trans controller with B&M Megashifter, 2500 Dirty Dog Convertor, 3.50 gears with detroit locker.
http://www.flickr.com/photos/36499599@N04/
http://www.youtube.com/watch?v=rbl-v...3&feature=plcp
Old 07-17-2013, 09:59 PM
I forgot about the Gear vendors overdrive which I will look into a used one,I plan on towing and a slide in camper so it might be the best option. They are pricy too so I better start saving up.
Old 07-17-2013, 10:27 PM
Dman64's Avatar
That's an option as well about the same price as the route I chose, only deciding factor for me was between the 2 was the GV OD is only .78 compared to the 4r70w which is .70. If you find a used one you will be fortunate, not too many people sell them as they are such a good unit.
FWIW
D
Old 07-18-2013, 07:32 AM
Was there ever a AOD made to fit the 460,I really do not want to mess with a computer to run the trans.
Old 07-18-2013, 04:15 PM
Dman64's Avatar
AOD no but E4OD yes but you still need a electronic controller which can be had for about $800.
D
  #7
Old 07-28-2013, 02:26 PM
customblackbird's Avatar
customblackbird customblackbird is offline
customblackbird First On Race Day
My C6 and 3000 stall is killing my highway cruising, trans tends to get to 220 pretty easily on a hot day only going about 20 miles on the highway. I've been looking into an OD for the trans as well and would like to hear what ppl have to say.
Your other options that I've found is an adapter plate to attach a 700r4 or a AOD to the trans. Adapter start around 450$. This is great as I have lots of experience with 700r4s on the past and they can handle 600-700hp and offer a lockup converter! That's going to be the single most important part of an OD trans swap.
The GV unit is nice but also has its drawbacks. Since the C6 doesn't allow for a lockup converter ur basically just stock with an extra gear, which will lower rpms but increase leverage so still expect your converter stall to be normal.
Basically I can cruise at 3k at 55-60mph since my stall is 3K, the GV unit will drop rpms but since I'm still under the stall of my converter and the added leverage of the taller gear means my converter will still likely stall at 3k at a slightly higher cruising speed. Only way to really lower cruising rpms is a lockup converter which also dramatically decreases trans temps. So your stuck with the AOD, 700r4, 4L60e, 4L80e, or the E40D or the other posted before.
1987 Firebird
521 BBF 10.8:1 FAST EZ EFI 2.0
2004R GM OD Trans swap, NX NOS kit
Insurance
Date of Birth
Month Day Year
Privacy
