Really thinking I want an overdrive transmission - 460 Ford Forum
Old 07-27-2013, 12:30 AM
customblackbird's Avatar
customblackbird customblackbird is offline
customblackbird First On Race Day
Default Really thinking I want an overdrive transmission
My 521 has a fully built C6 with a 3000 stall 10" non lockup converter. Rear gears are 3.55 in a ford 8.8, this is all stuffed in my 87 firebird. The trans used a deep aluminum pan, remote trans filter and also has a super duty trans cooler that's about the size of a radiator.
Its officially warm out and that means car shows and such and I drove my car to a show that was 20 miles away and my trans seems to be overheating. Engine temps get to 190-210 and my trans got to 220-225. This is cruising at 55-60mph at 2800-3000 rpms and its killing my motor and gas! I love the C6 bc I won't be able to break it but an overdrive with a lockup would be perfect and maybe I could actually drive this thing farther than 10 miles away. Trans temps drop to like 200 or so when I get off the highway and stuff.
Anyway I've been looking at my options. Either a E40D with a trans controller, and AOD or a block adapter with a 700r4 or something right? I've rebuilt a few 700r4s and they can handle 700hp reliably. I don't think I want the AOD and I think the E40D is also a good choice. I know the gear vendors unit are good but I loose alot bc I can't have a lockup converter with the GV C6 setup.
What do you guys recommend? And what's the cheapest route? I see the E40Ds for like 2000$ plus core charge and all I would need is a controller and my driveshaft shortened and such. 700r4 would be nice but the adapters are like 500$.
Motor is prob making 550hp and has a NOS kit but prob won't use it for more than 50-150 on track days which won't happen often.
1987 Firebird
521 BBF 10.8:1 FAST EZ EFI 2.0
2004R GM OD Trans swap, NX NOS kit
Old 07-29-2013, 11:33 AM
thermod thermod is offline
thermod First On Race Day
Don't sell the AOD short.Lots of fast SBF high hp cars out there with AOD.With your kind of power you might not be able to retain the lockup,however.Check these guys out....
FBperformance.com and the clickclickracing.com site.
Old 07-29-2013, 12:12 PM
Dman64's Avatar
Dman64 Dman64 is offline
Dman64 First On Race Day
From my research and why I chose the 4r70w is that it is newer and can be built fairly strong and it is built on the AOD platform. I considered the 700r4 but it is an older transmission and you can't get hard parts for them anymore, wreckers only. There area ton of 700r4's out there but in the end the all come out similar in cost for an OD. The E4OD can be built as well but in a lot of cases it's just too big to fit under trans tunnels.
D
Sent from AutoGuide.com App
1964 F100 466 zero decked fuelie 7cc dish pistons, with RHP 2.11 1.65 budget D3 heads, Voodoo cam 219/227, rpm intake, Holley Terminator EFI, MSD Ignition, MSD FORD TFI Distrbutor, 4R70W Trans with Baumann Re-cal kit, US Shift electronic Trans controller with B&M Megashifter, 2500 Dirty Dog Convertor, 3.50 gears with detroit locker.
http://www.flickr.com/photos/36499599@N04/
http://www.youtube.com/watch?v=rbl-v...3&feature=plcp
Old 07-30-2013, 01:46 PM
My racing buddy and best friend races fords, he has 2 fox body stangs. His drag car is a LX coupe stang or the "lightest" one with a very mild 302. Stock 302 with a small can and OTB aluminum heads, prob around 300ish Hp, then he hits it with a 100shot and the car runs 11.4s all day. He had his AOD built twice in a 1 year period, original AOD build had lots of money into it with alot of upgrades and he basically broke it 2nd time at the track. Welded one of the internals right together and lost reverse. Then getting it on the trailor he lost the rest of it. That's when we tore it apart to see what happened and now its been rebuilt again. It's this experience I want to stay away from the AOD, I've built a few 700r4s without any issues behind some 460hp
Motors. Basically I know what he put in the AOD and then again and it's way more than my 700r4 builds and they held up better.
1987 Firebird
Old 07-30-2013, 01:57 PM
Dman64's Avatar
It is personal preference, if you like the 700r4 do that it will do well. Check out this page, that is where I bought my adapter very pleased with it. There is a guy on this forum with a 700r4 behind his bbf, I think he is quick52 or something similar and he is very happy with his setup.
D
http://www.transmissionadapters.com/Pricing.htm
Old 07-30-2013, 09:52 PM
That adapter from that site which I saw is 875$!!! I thought these things were like 450-500$. That's the cost of a really good converter and will run more than the controller for the E40D.
Any cheaper ones?
1987 Firebird
  #7
Old 07-30-2013, 11:07 PM
Dman64's Avatar
You are $3000 easy for an OD but it is probably one of the best things I did. Just order a piece at a time and you will be happy.
D
  #8
Old 07-30-2013, 11:32 PM
windsor windsor is offline
windsor Driving a Ford
This is gonna be pricey whichever route you go. Cheapest (not by much) will prob be the E4OD, but that's a big SOB.
  #9
Old 07-31-2013, 06:40 AM
Ron95gt's Avatar
Ron95gt Ron95gt is offline
Ron95gt Driving a Ford
I bought the 4stb-e from FBperformance, to go with the PI lockup converter I already had.
It's almost ready to come off the jackstands, so can't really comment yet.
It has a fwd manual, with a button for OD and another one for lockup. When I tap the brake, both will disengage.
I live pretty far out in the sticks, so without OD, it would cost me a fortune to cruise into the cities.
On the other hand, with the price of the trans, I guess it would be accurate to say it STILL cost me a fortune to drive into
town. Ugh!
http://s640.photobucket.com/albums/uu123/Ron95gt1961/
523, P51's, 10.9 CR, FB performance 4STB trans, 1050, Mafia intake, Precision Industries 3800 lockup converter
  #10
Old 07-31-2013, 08:13 PM
PoweredByFord's Avatar
PoweredByFord PoweredByFord is offline
PoweredByFord Driving a Ford
4r70w with a JW bell and a constant pressure manual vb. with the right parts it will hold up, JW's bell is for AOD but will fit the 4r70 with minor modification, and they now make them deeper so you can use a true lockup converter, not the 2 input shaft mechanical type lockup the AOD has(that cant handle ****). Im building one right now to put behind my 521 SCJ headed motor
  #11
Old 08-01-2013, 07:49 PM
Well another reason I want to go 700r4 is that the trans tunnel was originally setup for a 700r4 so I know it will fit.
Does anyone have any pics of the adapters installed? Reason I'm asking is about firewall clearances and such. Does it push the trans bell housing farther away than the original C6?
  #12
Old 08-01-2013, 09:00 PM
My aod going into my 65 Falcon.
  #13
Old 08-01-2013, 11:10 PM
That's pretty nice! Who's bell housing is that? Prob with the 700r4 is the bell housing isn't removable.
1987 Firebird
  #14
Old 08-01-2013, 11:16 PM
Here is TCI's version to bolt any GM trans to the BBF and its only 489$
http://m.summitracing.com/parts/tci-529700
1987 Firebird
  #15
Old 08-01-2013, 11:20 PM
It's a JW Superbell AOD--->BBF
Was about $350 few years back. Have to cut off the stock bell of course.
