Really thinking I want an overdrive transmission - Page 2 - 460 Ford Forum
  #16
Old 08-01-2013, 10:52 PM
Dman64's Avatar
Dman64 Dman64 is offline
Dman64 First On Race Day
http://www.summitracing.com/parts/tci-529700/overview/
Another option.
Sent from AutoGuide.com App
1964 F100 466 zero decked fuelie 7cc dish pistons, with RHP 2.11 1.65 budget D3 heads, Voodoo cam 219/227, rpm intake, Holley Terminator EFI, MSD Ignition, MSD FORD TFI Distrbutor, 4R70W Trans with Baumann Re-cal kit, US Shift electronic Trans controller with B&M Megashifter, 2500 Dirty Dog Convertor, 3.50 gears with detroit locker.
http://www.flickr.com/photos/36499599@N04/
http://www.youtube.com/watch?v=rbl-v...3&feature=plcp
Old 08-02-2013, 05:24 PM
customblackbird's Avatar
customblackbird customblackbird is offline
customblackbird First On Race Day
That's exactly the same part I posted last lol.
Looks like a winner. Might be able to save some money as I might not need the flexplate. Think I remember mine being drilled for both ford and GM converters. Will have to check
1987 Firebird
521 BBF 10.8:1 FAST EZ EFI 2.0
2004R GM OD Trans swap, NX NOS kit
  #18
Old 08-03-2013, 10:27 AM
quick 52 quick 52 is offline
quick 52 First On Race Day
the adapter I used was a coan around $350... it is a mid plate also so I cut it down as close as I could to the engine.... not much left afterwards then I polish the outer 1/2" width looks great... with the coan setup you can use your ford flex plate and starter... and crank adapter will be needed also of coan $125... I have my 700r4 in a 1952 F1 truck behind a 472 BBF been working fine for 4 year's... Did take out the converter clutch doing full throttle lockups... Truck runs a best of 11.31 @ 118 on motor and !0.50s on hose
Drag week quickest street rod
2009 2010
  #19
Old 08-21-2013, 10:55 PM
Thanks guys, made up my mind. Got a used 2004R and just threw about $1350 into it to basically make it bullet proof to over 800ftlbs. Thinking ill have about $2,800 into the whole setup with everything including adapter kit, converter, lockup harness, DS lengthening. Went with the 2004R as they have a better gear selection, the 700R4's first 3.06 first gear used to annoy the hell outa me with a 450hp 383.
So the C6 will be for sale!
1987 Firebird
  #20
Old 08-24-2013, 02:35 PM
Dman64's Avatar
Make sure to do a build thread so we have another OD reference. Excited for you as my OD is one of the best things I have done for my rod.
  #21
Old 08-27-2013, 12:02 AM
Will do! I'm excited too. My next endeavor will be a fast EFI system!
1987 Firebird
  #22
Old 08-27-2013, 08:14 AM
Dman64's Avatar
Ha I'm going to do the new holley terminator efi and enable the timing control function. Great minds think alike.
  #23
Old 08-27-2013, 11:36 AM
One thing I haven't confirmed is the timing adjustment, does that mean we can't run a non ecu controlled distributer? Something like the duraspark wouldn't work correct?
Which distributers can we use?
1987 Firebird
  #24
Old 08-27-2013, 01:31 PM
Dman64's Avatar
Depends on the model but yours probably doesn't control timing, only the brand new versions do. You can keep your carb style distributor for the standard fast efi.
D
  #25
Old 08-27-2013, 11:23 PM
Yea that's what fast said too. But the standard fast EZ EFI is only able to support 550hp barely which means It won't work on mine correctly. Guy here is selling his barely used fast EZ EFI for like $900 but its no good for my application.
So basically most of the billet MsD and stuff basically just run a mag pickup and can't control timing either, fast said it would work with there new 2.0 version I believe. It prob just manipulates the signal from the distributer. I forgot to ask if they allow u to run an aftermarket CDI box as well
1987 Firebird
  #26
Old 08-28-2013, 08:51 AM
Dman64's Avatar
I know that the new holley terminator will work with a crank trigger or without, you have to run a TFI style distributor with it like the 8453. I contacted Danny Cabral and he highly recommended the new system, and he has a ton of tech work into the holley product. Plus I think the newer systems support upto 1200hp.
D
  #27
Old 10-14-2013, 07:38 PM
2004R swap thread has been created in driveline section!
  #28
Old 10-15-2013, 08:27 AM
CarsByCarl's Avatar
CarsByCarl CarsByCarl is offline
CarsByCarl Driving a Ford
How about a link?
