Np435 differences and yokes - 460 Ford Forum
Old 08-05-2013, 04:17 PM
ford or nothing ford or nothing is offline
ford or nothing First On Race Day
Default Np435 differences and yokes
i am having some trouble with the the smaller output shaft of the NP435 as its 28 spline and the only yoke i can seem to find is a stock one which i think is a 1330, and broke the yoke so welded on some metal straps all around it and clearanced it, now can keep a a u joint in it, so i want to switch to a 1410 joint so my question is how can i do this, can i just switch out the tail shaft to the bigger one that is a 32 or 35 spline that has a 1410 yoke option or have to change the whole tranny which will change my input shaft?
Old 08-06-2013, 10:46 AM
fpuller fpuller is offline
fpuller First On Race Day
I used the tail shaft from a F 600 truck. and had the drive shaft from the truck made to fit between the trany and the transfer case. the larger imput will also go in but it is longer. i had to build a different rear mount as the tail shaft housing was different.
Old 08-06-2013, 01:49 PM
alright so i can take the larger output shaft and put it in the tranny that has the smaller shafts (one with 28 spline and 1 1/16 input)? i want to keep the smaller input for now so i dont have to change clutch discs. how many spline is on the shaft that you put it? i would like to switch from the 1330 to a 1410 joint. and i think i can if the larger shaft is either 32 or 35 spline which i think some of the larger np435 shafts are
Old 08-06-2013, 01:56 PM
Thats what I did. But you have to change out the rear housing and the gears that slide on the shaft. they will match up teeth wise.
Old 08-06-2013, 02:03 PM
alright ill look into it, i just changes just the tailhousing last week cuz when i broke the yoke and everything it actually broke where the housing mounts, so i need to find one with a bigger shaft and switch out the housing, shaft, and gears as they must have a bigger bore i would assume? what are u running for a yoke now
Old 08-06-2013, 04:55 PM
the stuff i used came out of a early 70's u haul truck and i used that yoke. cant tell you the size of the joint but it was a monster and i had to get it from a truck shop. Dont forget to get the straps as mine were missing and they were hard to find.
  #7
Old 08-06-2013, 06:57 PM
What HP range are u in? Also the shaft and gesrs went right in with no matching just changed the tail housing? So ur using a small input? Or I could take a tranny with the big out put and put the small 1 1/16 input in it? .
  #8
Old 08-08-2013, 07:34 AM
hookin78's Avatar
hookin78 hookin78 is offline
hookin78 First On Race Day
If you do this and someone has a 1-3/8 larger input shaft and bearing retainer layin around I would buy it from ya.....
Brandon
Insurance
Date of Birth
Month Day Year
Privacy
