OEM R servo - 460 Ford Forum
Old 08-09-2013, 04:35 PM
501coup 501coup is offline
501coup First On Race Day
Default OEM R servo
Hey everyone. I just disassembled a c6 from a 72 Lincoln that I'm using as a parts tranny. It has a stock E lever and I think a stock R code servo as well as a 5 clutch drum and 4 pinion planetary. Is the stock "R" code servo pretty much the same as the sonnax and other aftermarket brands? I'm hoping it's one thing less thing I have to buy.
Also I'm thinking of buying the broader 500hp rebuild kit. My SCJ headed 501 should make around 550 fwhp and eventually I'll add a 200-250 shot. Does anybody care to share some tips on what other performance upgrades I will need besides what I got from the Lincoln and what's in the broader kit. Thanks
Old 08-10-2013, 10:24 AM
customblackbird's Avatar
customblackbird customblackbird is offline
customblackbird First On Race Day
The servo should have a code or letter on it to verify that its a R servo. IF it is an R servo then you should not need to buy a new one, they are just newer better looking copies of the originals with the same clamping force etc.
Broader is very good for the parts, hes very knowledgable as I have also gotten a good bit of parts from him to beef up my C6 that was in a lincoln. Mine is very stout though with a billet R servo, E lever, transgo shift kit and full Red alto clutches (max clutch pack sizes IE 5 clutch drums, all the internal upgrades and rollerized #9 bearing). Also sports pump mods for max cooling and a cast aluminum deep pan and has been converted to the more desireable short tail style. Mines behind me 550fwhp 521 BBF and has a 100-250 shot of NOS. Also has a 3000 stall 10" beefed up converter with Nitrous anti-ballooning plates and all the other goodies.
Only reason im saying all this is that Im prob going to be putting mine up for sale soon as I really want to go with a OD trans for more highway driving as I dont race really anymore. If you dont need the trans at this moment I should be pulling it by the end of sept in which case I would sell the whole thing whole with converter if your interested. This trans is setup for 800hp easily.
If not broader is good to work with!
1987 Firebird
521 BBF 10.8:1 FAST EZ EFI 2.0
2004R GM OD Trans swap, NX NOS kit
Old 08-10-2013, 06:32 PM
Thanks for answering the question it is an R code servo, so I'm all set. If I hadn't already bought a core I would be all over that trans, it's exactly what I plan to build. I doubt you'll have trouble selling it. Why not just throw a gear vendors unit on your existing trans? Wouldn't that be simpler than replacing the whole thing
Old 08-10-2013, 07:04 PM
Gear vendors cost about as much as a new trans setup. 2800$ and you need to disassemble the trans completely to remove the output shaft with the GV unit. After all said is done you still don't have a lockup converter which is a major difference. My 3000 stall is exactly where it's at 60mph basically right on the stall, 3k at 60 mph with a 521 sucking premium down to the tune of like 4mpg is not fun! gear vendors unit is only .78 overdrive and my trans will still stall at 3k but at more like 70mph.
A 700r4 with lockup gives me .70 overdrive and will turn like 2k at 65/70mph and really lower my trans temps.
1987 Firebird
