460 SCJ/P51 pistons....$499.95 - 460 Ford Forum
Go Back   460 Ford Forum > Classifieds > Vendor (FOR SALE)
Vendor (FOR SALE) This section is dedicated to all vendors who wish to place ads for their new products.
Closed Thread
Old 08-29-2013, 09:08 AM
CarsByCarl's Avatar
CarsByCarl CarsByCarl is online now
CarsByCarl Driving a Ford
Default 460 SCJ/P51 pistons....$499.95
Now available exclusively from CarsByCarl: Custom dual valve relief Probe 460 forged pistons at an off-the-shelf price!
These pistons are not available from any other retailer at any price. We have them in stock and ready to ship for only $499.95!
Price reduced....now only $399.95!
http://www.460ford.com/forum/showthr...46#post1165346
These pistons include the following features:
-Ideal for street/strip pump gas performance when using SCJ, P-51, OEM, Edelbrock, TFS, ProComp, or Blue Thunder heads.
-Dual reliefs allow you to build an engine with factory heads and upgrade to SCJ/P-51 heads without changing or modifying the pistons.
-.030 and .060 overbores available
-For use with stock dimension 460 crank/rods
-15cc effective dish
----10.5:1 compression with 72cc SCJ/P-51 heads
----10.2:1 compression with 75cc D0VE/Edelbrock/TFS heads
----8.7:1 compression with 95cc D3VE/Edelbrock/ProComp heads
-1.756 compression distance
-Piston weight = 679 grams
-Forged from 4032 alloy
-Wrist pins and Spiro locks included
-Can be used in press fit or floating applications
-5/64, 5/64, 3/16 ring pack
-Made in the USA!
Quick reply to this message
Old 08-29-2013, 04:53 PM
TommyK TommyK is offline
TommyK Driving a Ford
You're killing me (in a good way), what is the compression height?
Such a deal!
1973 Mustang Convertible
460 D0VE-C Heads w/CJ size valves, Lunati voodoo 227/233 cam, Edelbrock performer rpm manifold, FPA headers, Holley 950 HP carb, C6 w/2500 stall converter, 3.50 trac lock
Old 08-29-2013, 05:17 PM
CarsByCarl's Avatar
Such a deal!
Guess I forgot to list that.....1.756 compression distance.
Old 08-30-2013, 05:58 AM
HPbyGD's Avatar
HPbyGD HPbyGD is offline
HPbyGD First On Race Day
Are there enough material to make the dish deeper if needed and if so how much could be taken off ?
GD
Old 08-30-2013, 08:48 AM
CarsByCarl's Avatar
GD
Nominal thickness is .350", and the existing dish is .085, netting about .265" at the thinnest point. I'm not going to say how thin a guy could make the crown, that would be up to the person doing the modifications and any failures would be their responsibility.
If you want/need a bigger dish with an SCJ relief, we have other pistons available that don't need to be modified. PM or call for details.
Old 08-30-2013, 06:54 PM
RmK57's Avatar
RmK57 RmK57 is offline
RmK57 First On Race Day
Is that 10.25 cr with a 0 deck?
  #7
Old 08-30-2013, 07:22 PM
CarsByCarl's Avatar
All compression ratio figures listed above are based on a +.030 bore, .041 gasket, and .005 below deck.
  #8
Old 09-07-2013, 10:53 AM
Duane's Avatar
Duane Duane is offline
Duane Driving a Ford
Got mine today, awesome! Seems these would be good for a standard head too, much nicer than my old TRW dished pistons.
  #9
Old 09-07-2013, 08:40 PM
slowmoving1 slowmoving1 is offline
slowmoving1 First On Race Day
Will be calling around tax time for pistons and rod combo.
BTW nice pistons
  #10
Old 09-08-2013, 02:25 PM
butterbean butterbean is offline
butterbean First On Race Day
Default pistons
can they be baught in a flat top version?
  #11
Old 09-08-2013, 03:17 PM
CarsByCarl's Avatar
http://www.460ford.com/forum/showpos...6&postcount=51
  #12
Old 09-11-2013, 06:29 PM
CarsByCarl's Avatar
TTT
  #13
Old 10-11-2013, 06:00 PM
CarsByCarl's Avatar
Be sure to ask about top end kits to go along with these pistons. Custom tailored to your application.
  #14
Old 10-19-2013, 01:50 AM
Mr.Dyslexic Mr.Dyslexic is offline
Mr.Dyslexic First On Race Day
could I run a blower with these pistons with ether SCJ or DOVE heads?
  #15
Old 10-19-2013, 09:55 AM
CarsByCarl's Avatar
Depends on the application, but for street and/or pump gas use they'd work well.
Closed Thread
