intake manifold leak help - 460 Ford Forum
Old 09-22-2013, 10:05 PM
dohcsvt dohcsvt is offline
dohcsvt Driving a Ford
Default intake manifold leak help
I have this crate engine http://www.fordracingparts.com/parts...tKeyField=9289 and recently it developed an intake manifold leak. I mainly use it for cruising around town so I decided to replace the intake gasket with a victor reinz part # 95074sg. I did not use the cork end gaskets that came with it. I wanted to use permatex #2, but o'reilly's did not have that. They did have versa chem Gasket sealant type 2 so I got that (when I opened it I realized it was a black colored sealant?). I disassembled and thoroughly cleaned all surfaces (I noticed that FoMoCo originally assembled this motor with what appears to be clear silicone in place of the end gaskets). Anyway, I re-assembled everything torqued the manifold to 25 lbs/ft in 2 increments and then one last time around to verify torque. By the time I got everything else back on the engine it was about 1.5 to 2 hours later (more than long enough for the sealant to have set up, at least with my experience). Started the engine and all seamed well, let it worm up for a few minutes and all was well. I then blipped the throttle and water started squirting out of the front driver side corner of the manifold where it meets the head and block. Every time I would rev the engine it looked just like a squirt gun. DAMMIT! Does anybody have input as to a different gasket, or sealant or torque to use when I do this again next weekend. Did I not leave the RTV cure long enough? Any help would be appreciated.
Ottis
Old 09-23-2013, 04:38 AM
TommyK TommyK is offline
TommyK Driving a Ford
Superior formula remains soft and pliable to form a leak-proof seal
Slow-drying and flexible setting
Set time: 4 hours; Cure time: 24 hours
Ideal for permanent and semi-permanent assemblies
Seal and repair metal assemblies, new and used gaskets, and more
1973 Mustang Convertible
460 D0VE-C Heads w/CJ size valves, Lunati voodoo 227/233 cam, Edelbrock performer rpm manifold, FPA headers, Holley 950 HP carb, C6 w/2500 stall converter, 3.50 trac lock
Old 09-23-2013, 04:57 AM
gregaust gregaust is offline
gregaust Driving a Ford
Those VR gaskets are awesome. Something not right there. Check the bolts are not bottoming out maybe?
Old 09-23-2013, 08:27 AM
I just pulled the package out of the trash to re-check what I read yesterday. The set nor cure time are printed on the packaging. I specifically looked for that information. Just figured that the time to assemble the rest would be sufficient then. Thanks for the input, now I know for future reference
Yeah, I have read great things about them, guess I will be spending another $32 for another set to re-perform this job next weekend.
Thanks for the input.
Ottis
Old 09-23-2013, 09:03 AM
turbo2256b First On Race Day
I use the black permatex weather strip and gasket adheasive around the water ports and their copper silicone inplace of the end seals. Torked the bolts to 32 lbs (think thats the max).
Old 09-23-2013, 11:10 AM
Ottis
I don't have any patience either which is why I use this stuff:
http://www.autozone.com/autozone/acc...entifier=34502
Not cheap but it works.
  #7
Old 09-23-2013, 11:17 AM
Just pulled the intake back off. Approximately 20 to 21 hours after install and all of the sealant is still gooey and sticky. Not set up at all!! I have ordered permatex brand type 2 from amazon. I reviewed their web site data. It also gives 4 hours set and 24 hours cure. I guess I will just put it together one day and then fire it up 2 days later. Hopefully now that I know about the longer cure times it will work better this time. I will probably squirt a big gob onto a shop rag and check it over time and not run the engine until that gob is cured. Any input to my plan would be appreciated.
Ottis
  #8
Old 09-23-2013, 11:21 AM
Thanks for the input. I already ordered the other stuff. I know MANY MANY guys use it with great success. I will just be more patient as noted in my previous post
BTW, Tommy...NICE choice of automobile. The subject car that this engine is in is a 1973 Mach1. White with black stripes!. It could use some TLC, but it runs like a raped ape and looks good doing it! Thanks for all of your help.
Ottis
  #9
Old 09-23-2013, 11:51 AM
Ottis
Cool. For all things 71-73 check out this site.
http://www.7173mustangs.com/member.p...r&referrer=135
  #10
Old 09-23-2013, 11:10 PM
I just got home from work and 32 hours later this stuff is still not set up. When I pulled it off this afternoon and everything was still gooey, I decided to just let cure before trying to clean it off. So I went out tonight to look at it and it still squishy with areas that are still wet/tacky. I am giving thought to just using regular silicone.
  #11
Old 09-24-2013, 01:35 AM
ag460torino's Avatar
ag460torino ag460torino is offline
ag460torino Bleeding Blue
Default Just an FYI
Just an FYI. I like Loctite products so recently I decided to try their brand of "gasket maker". After doing installation I noticed this red stuff would not dry. I read the package and apparently you put a bead of it on one part and SPRAY AN ACTIVATOR on the adjoining part so that once you put it together the activator (or hardener as it seems to be compared to) mixes with the red loctite and reacts with it to set it up as a gasket making compound.
My mistake for not reading the back. I always used permatex and it was hanging beside it so I thought, what the heck.... MY BAD
Just an FYI for those who haven't run into that problem with the Loctite brand sealers.
  #12
Old 09-24-2013, 01:31 PM
cobrajetkid's Avatar
cobrajetkid cobrajetkid is offline
cobrajetkid First On Race Day
Permatex - Grey, tried & true. I have NEVER had to go back & re-do. Now that I've said that the next one will leak like a sieve LOL.
Good Luck!
Four sons & two 1969 mustangs, Life is GOOD !!!
My biggest fear is that when I die, my wife will sell all my cars & race parts for what I told her I paid for them !!!
  #13
Old 09-24-2013, 08:21 PM
beaterbike beaterbike is offline
beaterbike First On Race Day
x2 ultra gray very good sealer .
  #14
Old 09-25-2013, 09:02 PM
crittersf1's Avatar
crittersf1 Driving a Ford
Clear, 100% silicone in a caulk gun from Lowes.
  #15
Old 09-26-2013, 07:18 AM
kjett's Avatar
kjett kjett is offline
kjett Driving a Ford
I use the "Right Stuff" on the ends, but don't play around as you got a hot minute to get the intake down and start putting bolts in because that stuff sets up QUICK!
Insurance
Date of Birth
Month Day Year
Privacy
