600-650 reliable efficient hp?? - 460 Ford Forum
Old 09-23-2013, 02:44 AM
torinoman torinoman is offline
torinoman Driving a Ford
Send a message via AIM to torinoman
Default 600-650 reliable efficient hp??
I was planning on a 545 inch stroker and shooting for the moon for power and dropping it in a street driven Torino. However, I just had a moment of clarity and realized what overkill that is for what I would really wanna do with the car. What I really want is something that can provide factory levels of reliability and efficiency while making around 550RWHP through a t56 and a 9inch.
My end goal is a car I can drive cross country with only a lash check and an oil change while doing close to 20mpg.
I know I'm asking a lot but with the right heads, right cam and minimal cubes I think I can get damn close.
TL,DR; Think Z06 Corvette powered by a BBF
'71 torino gt m-code
now- 460 w/roller cam
one day w/t56
anyone wanna donate to my cause?
Old 09-23-2013, 03:11 AM
2slow 2slow is offline
2slow Driving a Ford
get a turbo Mod engine
Forgot . Have to ask. how many BBF 429/460's you know of that get 20 mpg? An adjustment in your wants is called for if a a BBF is a must . BTW , there are Mod engines out there that can do your wants.
Old 09-23-2013, 04:10 AM
A Z06 Corvette does well over 20mpg with 427ci. I don't think its unreasonable to ask IF and HOW a small inch high efficiency BBF can achieve similar numbers. Nor do I think its unreasonable to try to build a BBF for efficiency with optimal power instead of just stroking and adding a giant cam.
I know 20mpg and 600hp is a lot to ask for but so is 1000hp with P51 heads and a factory block but people still push the envelope. So don't tell me get a mod motor and turbo, that's counter productive. When people ask for easy way to 800hp do you tell them to find a Teksid block, 4v heads and 20lbs of boost?
Btw I rather do a LSx swap than cut my car up for a mod motor.... Not opposed to going back to a Cleveland though
one day w/t56
Old 09-23-2013, 05:48 AM
you said a lot but didnt answer How many BBF 429/460's you know of that get 20 mpg..
to answer your question about what I'd tell for 800hp, ONLY when they want 20 mpg
Old 09-23-2013, 07:00 AM
Imtruckinup Imtruckinup is offline
Imtruckinup First On Race Day
http://www.460ford.com/forum/showthread.php?t=167522
Maybe little bit smaller carb..VAC secondary of course... and a hydrogen kit.....I know of 1 selling some kits on here
http://www.460ford.com/forum/showthread.php?t=158897
Damn girl... You look better than a new set of mud tires
1993 f350 38's 5 speed. Toy
521 p51 headed pump gas street motor
639 hp at 5600 rpm
670 ft/lbs at 4300 rpm
Old 09-23-2013, 08:09 AM
TommyK TommyK is offline
TommyK Driving a Ford
I don't think the ZO6 example is appropriate. It has no where near 550 RWHP and GM had to go to extraordinary lengths to achieve the combination of power and economy it did. To get to that power level a supercharger is required. A Torino would also be at a major disadvantage in weight and aerodynamics as well.
The cam required to achieve the 550 RWHP N/A goal will most likely not produce the smooth low rpm operating characteristics dictated by the .50 overdrive and hwy mpg goal which the ZO6 achieves with a variety of high tech wizardry.
Of course it would be very interesting to see you try
1973 Mustang Convertible
460 D0VE-C Heads w/CJ size valves, Lunati voodoo 227/233 cam, Edelbrock performer rpm manifold, FPA headers, Holley 950 HP carb, C6 w/2500 stall converter, 3.50 trac lock
  #7
Old 09-23-2013, 01:00 PM
when he gets the carbonfiber body parts and aluminum suspension and engine block like the Z06 , there will be a great weight savings
  #8
Old 09-23-2013, 01:59 PM
And you answered none of my questions.
Is Torino vs Z06 apples and oranges? Sure! But I think its still a legitimate question to pose. How efficient can these motors get? How streetable reliable and efficient can a well thought out combination be? I don't think its ridiculous to pose these questions.
one day w/t56
  #9
Old 09-23-2013, 02:01 PM
CarsByCarl's Avatar
CarsByCarl CarsByCarl is offline
CarsByCarl Driving a Ford
I've done a 600 HP 460 that was reported to get ~18mpg with a manual overdrive trans and a carb.
What you're talking about is probably somewhat close to that assuming a 15% drivetrain loss. Making it a 429 might help with MPG's, a custom solid flat tappet, alum heads, dual plane intake, overdrive manual trans, and you might get close. Fuel injection would definitely help.
  #10
Old 09-23-2013, 02:12 PM
Thanks Carl! I think I remember you posting about that combination before. Can you elaborate on it a little. Heads cam intake carb compression?
And I agree, a 429 could get there and EFI would likely be a piece of that puzzle
one day w/t56
  #11
Old 09-23-2013, 03:15 PM
CarsByCarl's Avatar
In that particular combination, we used Edelbrock heads with an Air Gap intake, a hyd flat tappet cam, and fairly aggressive compression. The goal wasn't to make a mileage master by any means, it just happened to do pretty well.
  #12
Old 09-23-2013, 04:33 PM
To me it seems that to achieve these kinds of goals max compression is a must which means tight quench areas and a carefully selected cam.
As far as heads go, would P51s be too big?
one day w/t56
  #13
Old 09-23-2013, 05:33 PM
639 hp at 5600 rpm
  #14
Old 09-23-2013, 06:31 PM
CarsByCarl's Avatar
Edelbrock, TFS, or the new AFR heads are what I'd be looking at.
  #15
Old 09-23-2013, 06:51 PM
I figured the TFS would be the prime choice but I already have a set of ported P51s....
On a side note, has anyone actually put their hands on the new AFR heads?
one day w/t56
