Ball Joints - 460 Ford Forum
Go Back   460 Ford Forum > Full Race Tech > 4x4's, Pullers, Crawlers and other HD rides
4x4's, Pullers, Crawlers and other HD rides We don't need no stinkin' asphalt!
Old 09-24-2013, 04:25 AM
Danny Cabral's Avatar
Danny Cabral Danny Cabral is offline
Danny Cabral Driving a Ford
Default Ball Joints
Which brand ball joints do you like for Dana 44 & 60 axles?
Moog Problem Solver, Raybestos Professional Grade, McQuay-Norris, Napa Chassis Parts, Spicer, etc.
I like the ones that are greaseable after being installed.
I've had good service from Moog (their upper ball joint has the grease fitting angled at the bottom/side).
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, cold air induction, dual 3" exhaust/Magnaflow mufflers, 100HP progressive dry direct-port NOS, A/C, Lentech Strip Terminator wide-ratio AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim joint steering, Cage long radius arms, custom traction bars, 4" lift, 35" mud tires
Old 09-24-2013, 06:12 AM
crittersf1's Avatar
crittersf1 Driving a Ford
I use the MOOG with no problems.
Old 09-24-2013, 07:13 AM
kjett's Avatar
kjett kjett is offline
kjett Driving a Ford
Leave it to you to know about some other guys "ball" joints
But back to the original question, I run the Moog joints as well
Old 09-24-2013, 07:55 AM
575ciBronco's Avatar
575ciBronco 575ciBronco is offline
575ciBronco First On Race Day
I used to use moog but have been using the new napa chassis and have had really good luck. Super duty ball joints are about a joke but the napa chassis seem to last about the longest.
Derrick
Old 09-25-2013, 10:06 AM
Money-pit Money-pit is offline
Money-pit Driving a Ford
It's very important to set the right preload on them
Insurance
Date of Birth
Month Day Year
Privacy
