super cobra jet valvetrain? - 460 Ford Forum
Old 11-16-2013, 07:57 AM
ramair351 ramair351 is offline
ramair351 First On Race Day
Default super cobra jet valvetrain?
i just bought a 11/69 SCJ 429. i popped the valve cover off to check it out, and this is what i found. does this look like all the factory parts? did the solid lifter cars use a jam nut like this? how about that bottom spring cup?
Old 11-16-2013, 09:32 AM
rmcomprandy Bleeding Blue
Looks like a big block Chevrolet rocker arm to me. I could be wrong however, I was under the impression that the Ford "ball fulcrum" rocker arms were cast not stamped, (up until the "sled" type).
www.rmcompetition.com
CUSTOM ground camshafts
CNC porting
Old 11-16-2013, 09:40 AM
Flatrod Flatrod is offline
Flatrod First On Race Day
Looks like all factory except for the retainers, but I don't see the D0OE stamped in the giude plate. Spring seat and the jam nuts are right for a SCJ. At least it is the same as my two SCJ's.
Old 11-16-2013, 09:41 AM
that helps, so you think the valve spring retainers are not OEM?
Old 11-16-2013, 12:52 PM
The Mad Porter's Avatar
The Mad Porter The Mad Porter is offline
The Mad Porter First On Race Day
Cool
Not those are not Oem cj retainers....
Aftermarket for sure.
S
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
http://R-H-P.biz
"ReinCarNation High Performance" (253)-988-6648
http://www.facebook.com/SMJRHP#!/SMJRHP
Old 11-16-2013, 03:04 PM
FAIRMONT MIKE FAIRMONT MIKE is offline
FAIRMONT MIKE First On Race Day
I have a set of sled type rockers just like that on a set of c9's.
7/16" stud adjustable, with do guide plates.
  #7
Old 11-16-2013, 03:34 PM
CarsByCarl's Avatar
CarsByCarl CarsByCarl is offline
CarsByCarl Driving a Ford
That whole spring package looks like it's new aftermarket. And the rockers look like D3 sled style that have been retrofitted to 7/16 stud. I put a jam nut setup like that on a 351M, or 400 years ago to make the valvetrain adjustable. Think it might have been a kit sold by Crane or somebody.
  #8
Old 11-16-2013, 03:50 PM
Lem Evans Lem Evans is offline
Lem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue Path
The SCJ stuff I had was stamped rocker w/sled fulcrum 7/16" hole and w/o the 'foot' that the bolt down D3 fulcrums had.
B F Evans Race Parts
270-278-2376
  #9
Old 11-16-2013, 04:08 PM
Yeah, like he said!!
  #10
Old 11-16-2013, 06:12 PM
I believe the rockers are the same as Boss 302 and Boss 351. I agree with Carl the retainer and spring package is not OEM.
  #11
Old 11-16-2013, 06:36 PM
2slow 2slow is offline
2slow Driving a Ford
correct , rocker retainers , s/seats are the same as the Boss-351 and the Boss-302 except for the spring seat
  #12
Old 11-16-2013, 07:27 PM
turbo2256b First On Race Day
Retainers and possibly the spring cups aftermarket . Caant tell if the spring cups are stamped or machined. Machined would be aftermarket, stamped factory.
Thinking the jam nut had a piece it held down to deflect oil into the fulcrum.
  #13
Old 11-16-2013, 08:41 PM
BOSS 429's Avatar
BOSS 429 BOSS 429 is offline
BOSS 429 Driving a Ford
That is 100 percent correct,( EXECPT RETAINER'S) and has an added jam(lock) nut on top, cj and scj use same parts , as well as spring seat cups
the jam nut were sold over the counter because the locking nut( silver) would wear out
the part num not seen on guide plates on early engine is on the under side
RICH
CIRCLE (R) 815 712 8738
CLYINDER HEAD PORTING
COMPLETE ENGINES
632 557 532 598CI ETC
READY TO RUN OR DYNOED
  #14
Old 11-16-2013, 08:43 PM
BOSS 429's Avatar
also same as boss 302,and boss 351
RICH
COMPLETE ENGINES
  #15
Old 11-16-2013, 08:47 PM
BOSS 429's Avatar
And your a BBF ford guy?
THATS NOT A BALL fulcrum rocker, those are only on n code thunderjets
cast rockers are also a diff ratio then the stamp steel
RICH
COMPLETE ENGINES
Insurance
Date of Birth
Month Day Year
Privacy
