cam questions - 460 Ford Forum
Old 01-02-2014, 09:35 PM
garys gt garys gt is offline
garys gt First On Race Day
Default cam questions
Working on a 521 build with scj heads. What kind of profile of solid flat tappet cam would work good with this. Like to make as much power as possible. Would it be possible to have a cam that makes big power and not have to turn rpm up real high.
Old 01-03-2014, 01:02 AM
The Mad Porter's Avatar
The Mad Porter The Mad Porter is online now
The Mad Porter First On Race Day
Cool
Intended use, gearing, trans, vehicle type, weight etc etc will all have bearing on proper cam design... More information would be helpful.
S
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
http://R-H-P.biz
"ReinCarNation High Performance" (253)-988-6648
http://www.facebook.com/SMJRHP#!/SMJRHP
Old 01-03-2014, 02:29 AM
xoliex xoliex is offline
xoliex First On Race Day
i got a 521 with SCJ-A heads with a solid flat tappet and i make 509hp RWHP at 5900rpms and 521TQ RW at 4600 rpms. don't know if this is what you cal real high rpms or not. (note those numbers is to the ground and not the flywheel)
Call Scotty J at RHP (aka the mad porter) for details!!!
Old 01-03-2014, 03:52 AM
Street/strip 4000lb with 350 gear hope to get a big block c4 bell housing so I can c4 trans with 3000-3500 stall. Don't want to go any higher on stall. The c4 wont loose as much hp through it as a c6 would.
Old 01-03-2014, 12:44 PM
Cool
Unless you are after every last 10th get a C6... Especially true given your vehicle weight...
S
Custom ground cams
http://R-H-P.biz
Old 01-03-2014, 12:46 PM
torino501 torino501 is offline
torino501 Driving a Ford
coming in at 4000lbs that c-4 wont last long
  #7
Old 01-03-2014, 01:07 PM
Cool
Originally Posted by xoliex View Post
i got a 10.5 to 1 521 with SCJ-A heads with a solid flat tappet and i make 509hp RWHP at 5900rpms and 521TQ RW at 4600 rpms. don't know if this is what you cal real high rpms or not. (note those numbers is to the ground and not the flywheel)
Engine dyno numbers:
Net J-1349 / Uncorrected numbers
608 Hp / 633 TQ Sae net J-1349 pre 2004 .98 correction factor
626 Hp / 651 TQ Actual output. Air was very good that day.....
Engine carried 600+ HP from 5300 to 6200 RPM...
Track performance best 10.78 @ 126.94 mph. Race weight 3,700 pounds.
Build criteria was for a low 11 second street / strip build for a early 70's mach 1 (cow) On CALI 91 octane (cat piss) fuel.
Ask if you want build details.
S
Custom ground cams
http://R-H-P.biz
  #8
Old 04-03-2014, 01:03 AM
cory24 cory24 is offline
cory24 First On Race Day
Garage
Default What size stall for .584 .588 lift cam.
I have a 460 cobra jet engine with a 429 crank in it which makes it a 473. I jus put in a new comp energy extreme cam lift .584 .588 and I'm getting a built c4 and was wondering what size stall should I run.
  #9
Garage
AND what would be the best size carb to run
  #10
Old 04-03-2014, 07:28 PM
forestg forestg is offline
forestg Driving a Ford
If you have a 460 with a 429 crank you have a 429.
  #11
Old 04-03-2014, 08:44 PM
Money-pit Money-pit is offline
Money-pit Driving a Ford
No such thing as a " 460 Cobra Jet engine " Ford did make a 429 Cobra Jet engine though.
  #12
Old 04-03-2014, 09:16 PM
rmcomprandy Bleeding Blue
A 460 with a 429 stroke crankshaft is a 429 as the bore sizes are the same.
www.rmcompetition.com
CUSTOM ground camshafts
CNC porting
  #13
Old 04-05-2014, 06:03 PM
2slow 2slow is offline
2slow Driving a Ford
I thought winter was over, that a snow job on the 429 crank info. brown snow btw.
  #14
Old 04-05-2014, 09:37 PM
onlyfords's Avatar
onlyfords onlyfords is offline
onlyfords First On Race Day
Lmao
