Mild 460 for Monte1go - 460 Ford Forum
Go Back   460 Ford Forum > Tech Topics > Engine Build Archive
Engine Build Archive A place to archive DYNO or 1/4mile VERIFIED engine builds. Please post any engine tech questions to the Engine Tech forum.
Old 01-14-2014, 08:28 PM
monte1go monte1go is offline
monte1go First On Race Day
Default Mild 460 for Monte1go
Hey All. I had a great day at the dyno yesterday, and wanted to post my build. It's a pretty mild .030 over 460 and the carb is too small (Holley 770 Street Avenger)
Made ~ 8 pulls and played with air bleeds, timing, and jetting. ended up making best power with 82 front, 78 rear and 36* timing. I think I'm giving up a good amount (20hp or more) by only having a vac sec 770 CFM.
Engine Shortblock: 467 cu in - Stock Crank/Rods w/ARP bolts TRW Forged Pistons 10.2:1 Compression
Heads: Early small chamber (C8, C9, D0) with maybe a touch of cleanup
Cam: FMS M-6250-A443 (234*/244* @ .050" w/ .562/.588" lift I/E respectivley)
Valvetrain: 3/8 pushrods, Harland Sharpe Roller Rockers, Yadda Yadda
Made 430 hp, 461 lbft with a table top flat tq curve.
Old 01-14-2014, 08:49 PM
RocketcarX's Avatar
RocketcarX RocketcarX is offline
RocketcarX Driving a Ford
How much cash would you say you have tied up in the build? Just curious as the the build cost as I'm possibly doing something similar.
Old 01-14-2014, 09:39 PM
CarsByCarl's Avatar
CarsByCarl CarsByCarl is offline
CarsByCarl Driving a Ford
Good job! Power numbers seem to be in line. Still running that Stealth? I pretty much gave up on VS carbs for anything but a pure street car after wasting tons of dyno time on them only to bolt on a DP and gain 25HP on the first pull. Mid level gains were always huge too.
Looking forward to seeing some in-car reports!
Old 01-15-2014, 11:57 AM
Former429's Avatar
Former429 Former429 is offline
Former429 First On Race Day
Nice torque "curve". Should move that car nicely.
Old 01-15-2014, 03:09 PM
As far as cash I'd say about 3500. I got the engine newly built off a fellow 460ford.com member. About 3k for long block, plus I had to buy a new oil pump for my front sump setup. The engine came with front cover, valve covers (that'll prob get changed anyway) and the msd dist/box plus the stealth manifold (although I already had one on my old engine). If I sell all the other stuff I might end up south of 3k.
Also of note is there was significant interference between the intake and carb, and we had to do some grinding on the manifold...no wonder my 429 felt strong up to 3k and flat lined...Its the little things you find on the dyno that really make it worth it!
Old 01-15-2014, 11:13 PM
butterbean butterbean is offline
butterbean First On Race Day
good job, and really accurate numbers for your combo, I need to let mach1marc read this post, he's still mad over his build
Insurance
Date of Birth
Month Day Year
Privacy
