Trying to put a 460 in my mustang - Page 10 - 460 Ford Forum
  #136
Old 03-12-2014, 05:54 PM
mp40's Avatar
mp40 mp40 is offline
mp40 Driving a Ford
Originally Posted by Israel View Post
add some gas,.....
I think that his machine uses flux core wire.
1967 Mustang coupe, Mustang II front suspension. W/RV camed, D3VE headed, 460/C6 (soon to be 557 CID w/ported police interceptor heads) out of the box BBC headers(with homemade steel adapters)
Shocktower removal enthusiast.
The race is not over till the Fat Block Ford Sings!
FBHO
Old 03-12-2014, 09:26 PM
mustang1967 mustang1967 is offline
mustang1967 First On Race Day
add some gas,.....
Can't afford a gas welder and especially if I am just trying to learn and see if I want to pick up the hobby or not. Will just stick with my mig welder
  #138
You would be correct
  #139
Old 03-12-2014, 11:32 PM
Dman64's Avatar
Dman64 Dman64 is offline
Dman64 First On Race Day
I did most of mine with flux core and it worked fine. I did rent a tank and added gas to mine near the end as it just is easier but with that being said flux core will get the job done.
Best advice I ever got was when it sounds like bacon sizzling you have it just right. And who doesn't like bacon??
D
Sent from AutoGuide.com App
1964 F100 466 zero decked fuelie 7cc dish pistons, with RHP 2.11 1.65 budget D3 heads, Voodoo cam 219/227, rpm intake, Holley Terminator EFI, MSD Ignition, MSD FORD TFI Distrbutor, 4R70W Trans with Baumann Re-cal kit, US Shift electronic Trans controller with B&M Megashifter, 2500 Dirty Dog Convertor, 3.50 gears with detroit locker.
http://www.flickr.com/photos/36499599@N04/
http://www.youtube.com/watch?v=rbl-v...3&feature=plcp
  #140
Old 03-13-2014, 10:20 AM
Gydyup's Avatar
Gydyup Gydyup is offline
Gydyup First On Race Day
Flux core works fine on the floors, where your gonna hide the weld under seam sealer etc.
If you get into quarter panel work, it will indeed work but it will near double your prep time after you weld it. Also, gas gives you a much cleaner weld, its blowing the impurities away from your weld area. With flux core you will end up with a bunch of pin holes.
Be sure your using small wire, like 25. That makes a huge diff on finishing up the surface after you weld.
Bacon Sizzling - thats it D! I use that analogy teaching folk to weld every time.
But remember, when welding 18 - 22 ga car panels your really not welding. Your tacking, and I only hit it no more than it takes to get fussion, about the time it gets glowing, is right before it blows through. I hit it, really quick, touch it with a damp rag, move to the opposite side, hit it. Like tightening the wheel on a car, move around opposities. When I do panels its not really bacon frying its more a BZZZT move BZZZT move. Then just fill in the gap until you have full coverage.
Gydup -67 Coupe, 521 Kaase P51 Comp Solid Roller . Jerico DR4, narrowed & mini tubbed 9 inch with 4:56 spool , Mark Williams Axles on CALTRACS, Shaved towers.
Grabbing gears for 38 years.
  #141
Old 03-17-2014, 08:27 AM
Bigred69 Bigred69 is offline
Bigred69 First On Race Day
Exactly.
  #142
Old 03-17-2014, 11:47 AM
Gydyup's Avatar
Exactly.
Oh, big one. Do the corners last! As you work around its going to pull/move, I leave a little extra on the corners, radius the corners too. Squares dont want to line up well.
  #143
Old 03-24-2014, 05:07 PM
Israel's Avatar
Israel Israel is offline
Israel First On Race Day
Any progress?
Wife,........."You drove how far for that thing?"
Daughter,..."Theres no inside and it stinks."
Friend,......."Dude, thats a rusted piece of sheet."
Son,.........."This old car is cool."
USMC Security Forces, Kamiseya Japan, 0311
  #144
Old 03-26-2014, 09:42 AM
stumpy0227 stumpy0227 is offline
stumpy0227 First On Race Day
Hey, guys! I SUCK at figuring out these forums, except to find the right topic, and even that is rough on me, alot of times! I need serious help here, PLEASE! I a 68 Torino, Fairlane edition, and i bout an 87 460/C6 combo from a F250 truck. The engine/tranny combo only have 57,000 ORIGINAL miles on them, and I DON'T plan on going hog-wild with this, until I can afford it, and the engine starts to show some wear. I bought motor mounts (engine side) from a Mark 3 lincolon, running the 429, and left the 289 stock lowers in, as the research I've done says I can........
The big issue I am having now, is my stock 87 460 oilpan. It's front sump, and DEEP, but, that's tyhe problem! I was told this is the right pan to do this swap, but it doesn't fit. It hits the crossmember, and needs around 2-3 more inches, to go in where it needs to sit. Should I buy the correct pan, and, if so, which one do I need? OR, do I attempt to modify the pan I have, that has the drain plug at the lower rear, right where it hits? EVerything else has been thought out, planned, replanned, and fits correctly, EXCEPT the oil pan.
  #145
Old 03-26-2014, 10:42 AM
Israel's Avatar
Not sure how you wound up here, delete your post and open up a new thread by hitting, " new thread"
  #146
Old 03-27-2014, 05:31 PM
Any progress?
No progress yet I have been working way too much
  #147
Old 03-29-2014, 11:23 PM
Any progress?
Got a compressor and sand blaster and going to try stripping all the paint off so I can see what the body looks like under all that paint.
  #148
Old 03-30-2014, 12:22 AM
was also trying to look into the best way to stiffen the chassis so that I don't have to worry about the torque and HP causing the frame to flex. Any ideas?
