25.1E ----- 64 Fairlane - 460 Ford Forum
Old 03-03-2014, 02:48 PM
QKiss QKiss is online now
Location: Fortuna Ca Northern California in the redwoods
QKiss First On Race Day
Default 25.1E ----- 64 Fairlane
This is my first new thread. I'll see if I can figure it out with pics and all???
Humble beginnings ----- I know non of you guys have had projects start out like this ha ha. ----- This is my 10 second car project that got out of hand with a little help from my FREINDS ????
Wow looks like it might work.
Old 03-03-2014, 04:07 PM
butterbean butterbean is offline
butterbean First On Race Day
Great start, keep them coming
Old 03-03-2014, 10:33 PM
The car is now a roller and have pics so this will move along fast until we get to where the car is now. I don't want you to think I am building it this fast. There are a lot of photos so if you guys want more detail on something just let me know.
These are the tools used to cut out the body.
Saws all with metal cutting blades
Angle grinder with thin cut off wheel --- when the wheel gets small it is then used on the die grinder.
Die grinder -- adapters --and extended nose.
Spot weld cutters.
Body gutted and on the chassis jig.
Old 03-03-2014, 11:07 PM
Dman64's Avatar
Dman64 Dman64 is offline
Dman64 First On Race Day
Nice work, I'm subscribing to this thread. Now that's what you call gutted.
D
Sent from AutoGuide.com App
1964 F100 466 zero decked fuelie 7cc dish pistons, with RHP 2.11 1.65 budget D3 heads, Voodoo cam 219/227, rpm intake, Holley Terminator EFI, MSD Ignition, MSD FORD TFI Distrbutor, 4R70W Trans with Baumann Re-cal kit, US Shift electronic Trans controller with B&M Megashifter, 2500 Dirty Dog Convertor, 3.50 gears with detroit locker.
http://www.flickr.com/photos/36499599@N04/
http://www.youtube.com/watch?v=rbl-v...3&feature=plcp
Old 03-04-2014, 02:54 AM
gregaust gregaust is offline
gregaust Driving a Ford
Keep it comin' . Like those 64's
Old 03-04-2014, 09:05 AM
Modifying 1/4 panel opening.
The rear end is moved forward 2" to center the wheel tubs in the "C" post for max height.
This 9" full floater was looking for a home in our area for 3 years. I was very lucky --- it was a perfect fit.
  #7
Old 03-05-2014, 12:49 AM
Looking at the body on the jig it looked like the roof line over the top of front windshield was higher than the rear section. The decision was made to chop the top. 3" out of the front and 2" out of the rear and as it drops slide it back along the "C" post.
This shows a fixture for holding the top at the front. The top pins are stock location and lower pins down 3" and longer as a slider.
2" cut out of the back and holding tabs tack welded to top for positioning.
Copper chill plates clamped on both sides of the panel and tig welded 1" at a time and let cool to eliminate buckling.
Now that the body is roughed out we can get started on the chassis and cage.
  #8
Old 03-05-2014, 08:40 AM
The goal with the top chop was to be mild and not be real noticeable ------ The give away is the windshield angle.
  #9
Old 03-05-2014, 11:05 PM
Chassis and cage layout.
Frame --- 4Link brackets --- upper and lower 4link tubes.
Cage perimeter tubes fit close to the body.
Rear end housing fixture.
Rear frame section main tubes.
Cardboard wheel tub pattern is used to double check proper cage tube placement.
  #10
Old 03-06-2014, 08:29 AM
Tightly fit "A" post cage tubes.
Fitting funny car cage tubes ----- Once all the perimeter tubes are fit the body will come off for easy access to finish chassis.
  #11
Old 03-13-2014, 08:45 AM
Being set up for an A head 557 with P/G --- The mid plate is an adapter to chevy bell.
Note double frame rail ---- String is for door X bar layout.
  #12
Old 03-14-2014, 11:23 PM
DJW-Racing's Avatar
DJW-Racing DJW-Racing is offline
DJW-Racing First On Race Day
Send a message via MSN to DJW-Racing
Are you an experienced chassis builder? Layout looks very professional. Good work!
Derek.
1966 Mercury M-100
1976 Ford F250 4x4
  #13
Old 03-14-2014, 11:53 PM
c.evans c.evans is offline
c.evans Driving a Ford
It's looking good. Keep up the excellent work!
Charlie Evans
  #14
Old 03-15-2014, 01:23 AM
Thanks guys its always appreciated when your work is noticed.
Yes Derek I am basically a no name chassis builder from a no name town and have been building since 1978. The Fairlane is my personal car and there are things being done to it that time wise would be cost prohibitive for most customers. It is fun to do a project without being on the clock. With that said if anyone has any questions I may be able to help with I would be glad to add my two cents. Thanks again.
Steve
  #15
Old 03-15-2014, 09:16 AM
jeffgfg jeffgfg is offline
jeffgfg Driving a Ford
Thumbs up
Very nice!! Keep us up to date with pics!!
