25.1E ----- 64 Fairlane - Page 4 - 460 Ford Forum
  #46
Old 04-07-2014, 08:17 AM
Gydyup's Avatar
Gydyup Gydyup is offline
Gydyup First On Race Day
This car is stunning.
Gydup -67 Coupe, 521 Kaase P51 Comp Solid Roller . Jerico DR4, narrowed & mini tubbed 9 inch with 4:56 spool , Mark Williams Axles on CALTRACS, Shaved towers.
Grabbing gears for 38 years.
Old 04-08-2014, 11:04 PM
QKiss QKiss is offline
Location: Fortuna Ca Northern California in the redwoods
QKiss First On Race Day
Thanks ------- As the car moves through its different stages the more and more I like it. It has evolved ----- waaaaaay ----- past the original idea for this car.
Cowl skin underside
The cowl opening closed in on both sides of center that will be cut out for carb access and also the wiper pockets filled in.
The underside panel cut --- fit --- and held in place with clamps for welding.
The cowl / Firewall transition is made from 22 gauge cold rolled steel.
The center cutout is boxed in and will be covered by the rear of the hood scoop
Now we can proceed with the firewall.
  #48
Old 04-09-2014, 07:08 PM
badsnake306 badsnake306 is offline
badsnake306 Driving a Ford
sick build...one of these days ill own a car like yours
1988 F350 BBF
  #49
Old 04-09-2014, 07:35 PM
Gmsmkr's Avatar
Gmsmkr Gmsmkr is offline
Gmsmkr First On Race Day
Thumbs up
At a lost for words just stunning. Great work!!! Can't wait to see it all put together
Tag and ins it's a street car, how it gets there does it really matter?
Nobody's perfect but if u drive a ford your darn close.
  #50
Old 04-11-2014, 12:00 AM
Thumbs up
Thanks guys ----- You know badsnake a statement like that is how these cars get started.
  #51
Old 04-11-2014, 12:43 AM
Firewall poster board pattern development.
Transferring pattern to sheet metal.
Transfer punch and ring adapter used to pickup tube centers for knockout punches.
bead and brake line layout.
  #52
Old 04-11-2014, 09:43 AM
347Maverick 347Maverick is online now
347Maverick First On Race Day
Thumbs up
Outstanding work, thanks for sharing!
  #53
Old 04-13-2014, 11:30 PM
Firewall trans tunnel opening ---- drivers side.
Trans opening from engine side showing small diameter 4130 tube reinforcement/stiffener.
Panels with the edges finished, holes drilled and clecoed in place.
Stiffener tube stitch welded to the 22 gauge mild steel firewall.
Right side of pic shows a receiver flange for the front of the aluminum trans tunnel sides.
  #54
Old 04-16-2014, 12:38 AM
Forming the rear drive shaft tunnel panel that goes between the upper and lower 4 Link tubes.
Panel being hammer formed.
Finished trans tunnel flange.
Panel held in place with dzus fasteners ready for tunnel.
The decision was made to make a stand alone drive shaft tunnel rather than just boxing in the double frame rails.
This leaves more room for mounting accessories.
Tunnel fit around rear panel flange.
  #55
Old 04-16-2014, 08:18 AM
blu69machI's Avatar
blu69machI blu69machI is offline
blu69machI First On Race Day
Garage
This is just a great detailed thread man. I dream to be able to do what your doing, amazing work sir.
  #56
Old 04-16-2014, 03:48 PM
Thank you.
People with good mechanical aptitude can acquire the skills to do any of this.If you are on this forum and work on your own car its a pretty safe bet you qualify . Just takes getting involved , searching for answers to your questions and practice. A few tools help also.
If you guys have any questions I may be able to help with let me know. I have no secrets. I'm just a guy like you that has been banging my head against this stuff since 1978.
Steve
  #57
Old 04-20-2014, 11:11 PM
Picking up angle for firewall to trans tunnel transition flange.
Setting band saw table angle.
Cutting out hammer form blocks with preset table angle.
Aluminum clamped in blocks ready for the hammer forming.
Finnished flange.
Flange riveted to firewall panel.
The panels were dimpled and flat head flush style smash rivets were used.
4 dzus buttons are used to fasten the finished transition panel to the firewall.
  #58
Old 04-21-2014, 09:30 PM
Mustang-Junky's Avatar
Mustang-Junky Mustang-Junky is offline
Mustang-Junky First On Race Day
Looks great. Really nice touches. Keep the pictures coming.
Jess
'90 mustang 545, Weiand tunnel ram, Predator carbs, c-4 with brake, 4800 stall UCC, 9" 4.10 gears, 390/45r 15 drag radials, ladder bars.
  #59
Old 04-21-2014, 09:54 PM
onequickstang's Avatar
onequickstang onequickstang is online now
onequickstang Driving a Ford
Garage
That's just amazing stuff. If you were in NY, I'd be knocking on your door asking to do my car next! Please keep it coming.
'68 Mustang Fastback. Coming soon - all aluminum 548 A441 Hemi! Gonna be one bad FoMoCo!
  #60
Old 04-22-2014, 03:47 PM
Thanks guys.
The next pics will be of the trans tunnel. It will be a 3 piece unit with dzused in sides and a removable top.
