PETERSON FUILD SYSTEMS and CIRCLE R MANDREL - 460 Ford Forum
Go Back   460 Ford Forum > Non-Tech Topics > Chilly's Garage
Old 03-12-2014, 06:45 PM
BOSS 429's Avatar
BOSS 429 BOSS 429 is offline
BOSS 429 Driving a Ford
Default PETERSON FUILD SYSTEMS and CIRCLE R MANDREL
Finally done with a PROTOTYPE that will FIT an ATI 3 BOLT DAMPNER with the bbc pattern for use with the BOSS snout, or std length snout, And a BBF with an ATI 3 bolt damper with the large ford hub, and std length crank
Been working on this for a while. I finished the first one, and PETERSON now has the drawing and it will be marketed thru PETERSON FUILD SYSTEMS
Some of you already know it's a pain to come up with some of our ford front drives. And it's always been a problem . It will also fit the stock 429/460 damper with the large hub. Now we will have one that will fit 3 or 4 bolt. as in BHJ ,FORD MOTORSPORT ETC .
I will be testing for fitment, and length for vac pumps, alt's, water pump, etc in the next few weeks .with, and with out motor plates. I may not be able to cover all the different apts, but I will cover a few.
Yes will be a spline drive ,not a keyway.
For those of you that also shorten the crank another .250 for use with the ati sbf hub I already offer a spacer so this mod is not needed. works with std timing cover, and belt drives.
I also make a locating ring for the crank trigger wheel with ati damper that will work with the Peterson mandrel's with the bbf/sfb hub
Thanks-Rich
RICH
CIRCLE (R) 815 712 8738
CLYINDER HEAD PORTING
COMPLETE ENGINES
632 557 532 598CI ETC
READY TO RUN OR DYNOED
