86 f250 engine swap oil pan question - 460 Ford Forum
Go Back   460 Ford Forum > Full Race Tech > 4x4's, Pullers, Crawlers and other HD rides
4x4's, Pullers, Crawlers and other HD rides We don't need no stinkin' asphalt!
Old 04-05-2014, 07:36 PM
jsull36 jsull36 is offline
jsull36 First On Race Day
Default 86 f250 engine swap oil pan question
I cant seem to find any oil pan to fit this (based on specs as compared from oem to aftermarket).
I have an 86f250 originally with the 6.9 diesel, I am in the process of totally converting to gasoline and putting in a nice d0ve-a 429 with d0ve-c heads, bored 60 over and flat top pistons. the only things left are carb and oil pan. any suggestions? canton makes a few good 4x4 pans but nothing that fits both. did the bolt pattern differ between 70 and 86?
this truck will be mostly on the road, punch the pedal and what not but occasionally I have to take the 38 inch tires off road!
thanks for the input guys
Old 04-05-2014, 09:34 PM
onlyfords's Avatar
onlyfords onlyfords is offline
onlyfords First On Race Day
I am replacing a 460 in an F250 4x4 with a '70 429. Both engines have rear sump pans. Both are factory. 1 is 8 1/4" deep, ( stock '86 pan) the other is 8 5/8" deep. Can get the part number off that one if you like. Also, jfyi, that 429 will also need the old style flex plate/fly wheel. Good luck.
Old 04-05-2014, 09:36 PM
onlyfords's Avatar
Its also an '86 that I'm working on.
Old 04-05-2014, 10:22 PM
Yes I would like the part number very much so! Thanks! Here's another question since you've got the same 429, what are the stock stud sizes on the rockers?
Old 04-05-2014, 10:40 PM
onlyfords's Avatar
I will have to. The measurments tomorrow when its light. 3/8 I think. I changed to D3VE heads and the DOVE's are right there, easy to measure for ya.
Old 04-05-2014, 10:59 PM
onlyfords's Avatar
Studs are 3/8.
  #7
Old 04-05-2014, 11:19 PM
onlyfords's Avatar
Part number must be inside the pan. Not seeing it now. Seems it was a D4?? Thunderbird pan. The two pans also take different oil pumps and pickup tubes. As for carbs, I' ve ran both Edelbrock 600 and 750 on the 460. Good mileage and respose from the 600, ran outta breath at about 4800. I'm going to try the 750 on the 429, its set up to breath a little better.
  #8
Old 04-06-2014, 07:48 AM
Thanks for all that info. I was hoping it was 7/16 on the rockers though since all the after markets are pretty much 7/16. I'm trying to put together a performance build to hit the mud and the track here and there but mostly just a street machine; any other tips or suggestions on mods that I can get that aren't too crazy on the wallet? Money isn't a big deal but I don't wanna dump 10k on this thing. I already have intake, water pump, new rods and cam with a mid-way lift and duration, billet timing chain, all new bearing, 60 over flat top pistons too. I feel like I'm forgetting something.
Thanks again man!
  #9
Old 04-06-2014, 08:29 AM
onlyfords's Avatar
These were screw in studs, not pressed. If yours are same shouldnt be too bad to change out. For what your doing I thing I would step up to good roller rockers and hardened push rods. Good valve springs that match up with the cam. Dist.?
