D9TE and 4.5 stroke - 460 Ford Forum
Old 04-05-2014, 08:19 PM
fordguy69 fordguy69 is offline
fordguy69 First On Race Day
Default D9TE and 4.5 stroke
Do any of the readily available internally balanced 4.5" strokers fit in a D9TE block without clearancing?
If so which ones?
Old 04-05-2014, 08:57 PM
The Mad Porter's Avatar
The Mad Porter The Mad Porter is offline
The Mad Porter First On Race Day
Cool
If so which ones?
The Scat and Eagle cranks fit great.
S
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
http://R-H-P.biz
"ReinCarNation High Performance" (253)-988-6648
http://www.facebook.com/SMJRHP#!/SMJRHP
Old 04-06-2014, 09:02 AM
CarsByCarl's Avatar
CarsByCarl CarsByCarl is offline
CarsByCarl Driving a Ford
If so which ones?
All of them.
They're all modeled after the 3Y crank's dimensions, so they'll fit in any of the production blocks.
Old 04-06-2014, 12:26 PM
Thanks Scotty and Carl, you guys are the best!
Old 04-06-2014, 01:02 PM
Cool
I didn't mention the plethora of other offerings because we have no direct experience with them.
Glad to help...
S
Custom ground cams
http://R-H-P.biz
Old 04-06-2014, 08:12 PM
rmcomprandy Bleeding Blue
The cranks all fit without a problem however, some clearancing MAY be necessary, depending upon which rod is used.
www.rmcompetition.com
CUSTOM ground camshafts
CNC porting
  #7
Old 04-06-2014, 09:35 PM
69F100's Avatar
69F100 69F100 is offline
Forum Contributor
69F100 Driving a Ford
No clearance problem on my d9 with the 4.5 and 6.7 h beam rods the are RPM's
  #8
Old 04-06-2014, 10:54 PM
NOW ... with your 4.500" stroke crank, put in a less expensive production type, steel rod using a 2.200" bearing with "through bolts" and every rod big end will contact the bottom of a bore.
CNC porting
  #9
Old 04-06-2014, 11:27 PM
68xr7cat 68xr7cat is offline
68xr7cat Driving a Ford
And just think how the clearance would be with an Aluminum rod!
Insurance
Date of Birth
Month Day Year
Privacy
