Engine Tech A place to discuss all 385-series engine tech and theory
Old 03-01-2006, 06:39 PM
skipped_link skipped_link is offline
skipped_link
Default New video
Not much for tech, but after actually getting to drive my project I thought I would share my latest video, (for the FTE guys it's the same one I posted over there),
I did not get much on video, shortly after this shot I broke an axle & I'm waiting for parts,
Here is a link to the video,
http://videos.streetfire.net/video/7...650C83A278.htm
Leroy Latham
  #2
Old 03-01-2006, 07:14 PM
ccso640's Avatar
ccso640 ccso640 is offline
ccso640
Default cool
Killer ride, that thing looks like a pissed off version of the truck on the movie Jeepers Creepers lol. Nice, Chris
Old 03-01-2006, 08:25 PM
P.Lafferty P.Lafferty is offline
P.Lafferty
Default That truck is MEAN!!!!!!
Lets hear some specs on that bad boy! Grea job!!!!!!!! Patrick.
Old 03-01-2006, 10:46 PM
71f150 71f150 is offline
71f150
Default MORE!!!
POST MORE VIDEO!!!!
Dang that things got a note to it...
Congratulations!
Cheers,
Propane Steve
Old 03-01-2006, 10:57 PM
gvos
Guest
Posts: n/a
Default Yikes
I'd hate to meet that in a dark alley :shock: JK, she sounds really good, give us more when your back on the road.
Old 03-02-2006, 05:50 AM
Danny Cabral's Avatar
Danny Cabral Danny Cabral is offline
Danny Cabral
That thing is awesome!!! I love the way it looks and sounds. I also, would like to know more about the vehicle and more action videos as well (not so far away). Got a webpage?
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, C950 EFI, A/C, Lentech Strip Terminator wide-ratio AOD, 3:1 Atlas II, max built Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim-flip steering, Cage long tubular radius arms, 4" lift, 35" tires
  #7
Old 03-02-2006, 09:52 AM
skipped_link
Thanks for the kind words guys,
A short run down on the engine,
SVO block 4.530 bore
offset ground 429 truck crank 3.77 stroke
old style SVO A-heads
trickfow A460 tunnel ram modified for blown application
Little field 14-71 hi helix, delta plate blower, & Enderle bird catcher,
The truck is a 49 ford on a 79 bronco frame, 4 link front & rear with king 14" coil over shocks, Dana 70 diffs front and rear,
A-1 built C6 & converter and a home made drop box,
As of right now I do not have any other videos, but if my new axles show up this week I'll get more this weekend,
Here is a link to some pictures that I took throughout the builup,
http://pg.photos.yahoo.com/ph/skippe.../ph//my_photos
and here are a few pics of the engine while I was making a few changes
If I get more time later I'll post all the specs I know about the engine and get your opinion on HP output,[/url]
Leroy Latham
  #8
Old 03-02-2006, 12:16 PM
Phantasea466 Phantasea466 is offline
Phantasea466
Rock On Dude :!:
Looks and Sounds BAD *** :twisted:
Damon Sea
1983 Mustang NMRA OC9534
Thanks to my sponsors
Performance Crankshaft Inc. www.performancecrankshaft.com
BMR Performance aka Bill Mitchell http://s254.photobucket.com/albums/hh93/85monte_ss/
Evans Racing Engines www.evansracingengines.com
BF Evans Ford www.bfevansraceparts.com
"If it doesn't fit, Force it. If it breaks then it needed to be replaced anyway"
http://photobucket.com/albums/f75/Phantasea466
  #9
Old 03-03-2006, 05:56 PM
P.Lafferty
Default What did...
What did you use to run the rad in the rear? Aluminum tubing? And also what rad did you use? Thanks Patrick...
  #10
Old 03-03-2006, 07:34 PM
skipped_link
I used 2" aluiminum tubing, the radiator was going to be a summit aluminum unit or a chevy, but after deciding to go blown alky, I just hooked the two aluminum tubes togeather, the water now just makes a loop down the frame & back, the whole system holds 5 gal, the highest I've seen the temp after about 15 min, of driving was 150-160,
The reason for running the chev radiator was so the inlet & out lets woud be on the correct side since the rad. was in there backwards,
Leroy Latham
You may not post new threads
You may not post replies
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
