Best spark plugs and wires. - 460 Ford Forum
Old 03-14-2006, 12:25 AM
Dale578 Dale578 is offline
Dale578 Driving a Ford
Default Best spark plugs and wires.
Hello all. What's the best plug wire to use. Who has had the best luck and performance with their brand? I have a 578cid, 13.2:1 comp, A460 heads, mid .700 lift roller, Msd 7al and a Msd billet dist. Also, what plug should I use as a starting point. Thanks..................Dale.
Old 03-14-2006, 08:01 AM
ProStreetFairlane's Avatar
ProStreetFairlane ProStreetFairlane is offline
ProStreetFairlane Driving a Ford
Garage
I know lots of guys swear by the big Moroso wires and many use Taylor wires.
Old 03-14-2006, 04:28 PM
Danny Cabral's Avatar
Danny Cabral Danny Cabral is offline
Danny Cabral Driving a Ford
The MSD 8.5mm Super Conductor wires have served me well, however, I'm not using a race only, high output ignition system (such as a MSD 7 or 10).
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, cold air induction, dual 3" exhaust/Magnaflow mufflers, 100HP progressive dry direct-port NOS, A/C, Lentech Strip Terminator wide-ratio AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim joint steering, Cage long radius arms, custom traction bars, 4" lift, 35" mud tires
Old 03-14-2006, 06:33 PM
jpierce55 jpierce55 is offline
jpierce55 Driving a Ford
Taylor Vector's are the best I have had, outlasted my Accels by a long shot on top of the fact you can get various colors.
Old 03-14-2006, 11:11 PM
Default Maybe I should have asked,
are there any plug wires, or types of plug wires that are not compatable with the MSD 7al?
Old 03-15-2006, 02:05 AM
ivanribic ivanribic is offline
ivanribic Driving a Ford
I'm running MSD 8.5's now and I'm very happy with them. I'll never buy another set of Accels. My truck spent almost 3 weeks sitting in the driveway before I finally narrowed down the problem to some near new Accel wires that were toast. They may work fine with a stock ignition but seems they can't handle the MSD stuff for too long. Taylor's would be my next buy, the 10mm wires.
78 F250 Supercab 4x4
  #7
Old 03-15-2006, 08:47 AM
A long time ago (when I was a kid), I purchased a complete Accel ignition system. I had trouble with the coil and wires.
  #8
Old 03-15-2006, 09:15 AM
ProF100 ProF100 is offline
ProF100 Driving a Ford
I have tried Accel 300+, MSD, and now have the Morosos'. The Accels did fine for two years and then failed. The MSD units are nice and I swear the Morosos' look like they are made at the same place as the MSDs. I bought the Morosos' because they were blue instead of the red MSDs. They appear to be the same good quality. The crimping tools are much better with the MSD stuff and you get more extra pieces. I would go MSD universal fit and make them fit perfect. They will supply you with a nice strip gauge/crimping tool that you can put in the vise instead of that hammer deal. The Moroso stuff didn't come with anything but wires and ends.
David
David Willingham
Advanced Motorsports Engineering
  #9
Old 03-15-2006, 11:31 PM
Thanks alot guy's. I appreciate the feedback...............
