How do you test a Duraspark pick-up assembly? - 460 Ford Forum
Old 03-22-2006, 08:57 PM
ifergusson ifergusson is offline
ifergusson Driving a Ford
Default How do you test a Duraspark pick-up assembly?
I am not getting any spark out the Duraspark ignition on my truck and I think it is the pick-up coil as I have eliminated every other possibility I can think of and managed to isolate the problem to the distributor.When I measure the resistance across the coil I get about 540 ohms which is within specs and I also get infinite resistance between the wires going to the pick-up and ground.Is there another test I can do as I hate to replace it if it is good.
Old 03-23-2006, 06:46 AM
cdeal28078 cdeal28078 is offline
cdeal28078 Driving a Ford
I saw a way to do this one time that I thought was pretty cool but can't remember everything about how he did it.
He basically hot-wired the engine and removed a plug wire and placed it near a ground. He then used a 110v electric razor and held it close to the pick-up in the distributor. That thing went crazy firing the plug wire. Might be more too it but that's all I remember. Worked like a charm though, I remember that and pretty much tested everything in the system.
clint
1971 Ford F100, 460/c6
PS, PDB, Auto, 3.0 gear
Old 03-23-2006, 08:51 AM
Danny Cabral's Avatar
Danny Cabral Danny Cabral is offline
Danny Cabral Driving a Ford
Let's test this the conventional way (using an ohmmeter). MSD uses the same type of magnetic pick-up coil as the Ford Duraspark:
http://www.msdignition.com/pdf/tech%...ic_trigger.pdf
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, cold air induction, dual 3" exhaust/Magnaflow mufflers, 100HP progressive dry direct-port NOS, A/C, Lentech Strip Terminator wide-ratio AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim joint steering, Cage long radius arms, custom traction bars, 4" lift, 35" mud tires
Old 03-28-2006, 08:46 AM
I just thought I would post an update and maybe help someone else out with the same problem.The pick-up tested fine with an ohmmeter.I pulled the distributor and set up a temporary Duraspark ignition system on my workbench.If I used the distributor only as a triggering mechanism and put a spark plug at the end of the coil wire I had a good spark but if I routed the spark through the cap and rotor I got nothing.I replaced the cap and rotor with another one and it worked fine.I have never had a cap/rotor suddenly fail but that seemed to be the culprit.
Insurance
Date of Birth
Month Day Year
Privacy
