'96 f-350 4x4 460/5 speed/3.55 all done at 3500rpm....why? - 460 Ford Forum
post #1 of 5 (permalink) Old 10-21-2007, 10:03 PM Thread Starter
nice running truck gets good fuel mileage - for a 460 and never gave me any problems since 2000 when I bought it - has 99k miles now
runs OK but runs out of steam at 3500 rpm - no point in trying to rev higher - seems not much faster than a 5.8 liter
I had a 1986 f-250 460/4 speed stick years ago and it was a rocketsled compared to this truck
is 3500 rpm all I can expect or might I have weak valve springs or something? - Im using the stock tach to see rpms
Buffalobob is offline
post #2 of 5 (permalink) Old 10-22-2007, 09:43 AM
Lean?
Fuel filter?
www.RaceSystems.com
ByronRACE is offline
post #3 of 5 (permalink) Old 10-22-2007, 10:02 AM
My 89 is done at 4000 rpm ,actually hard to get it to 4000 rpm ,unless you floor it on a hill,but it stops pulling at about 3500.
The restrictors{air horns} in the intake track in mine are like the size of dimes its breathing thru.
shawnlee is offline
post #4 of 5 (permalink) Old 10-22-2007, 02:17 PM
Check the fuel pressure.
Leadmic
leadmic is offline
post #5 of 5 (permalink) Old 10-22-2007, 02:28 PM
1. Change air filter
2. Change fuel filter
3. Check timing
4. Check fuel pressure
The first and second probably need to be done anyway. The third is easy and can't hurt. The fourth is free if you have a guage and the gauges are cheap if you don't.
Brad
Brad Johnson is offline
