557" AFR 300's Street build 750+ HP @ 6,100 - Page 2 - 460 Ford Forum
 10Likes
post #16 of 46 (permalink) Old 10-23-2016, 02:37 PM
nickbay's Avatar
Quoted: 20 Post(s)
valve covers
Did you have to do anything to the (I think) Blue Thunder valve covers as far as clearance goes inside of them?
http://s212.photobucket.com/albums/cc110/laveennick/
nickbay is offline
post #17 of 46 (permalink) Old 10-23-2016, 03:28 PM Thread Starter
Quoted: 521 Post(s)
As noted in the FB album the BT cast valve covers have to be clearanced just as with the SCJ and P-51 castings.
Using a 1643 felpro (thicker) helps. The baffling has to be clearanced for poly locks as well. Kind of a pain in the ***.
The motorsports tall valve covers fit with no mods.
post #18 of 46 (permalink) Old 10-25-2016, 09:52 PM
bob460's Avatar
Quoted: 216 Post(s)
MP is the intake the same height as a victor?
Why not use a girdle with the rockers?
Why not 7/16 pushrod?
Cheers, Bob
Ps- Did you see the afr headed build on the other site?......solid roller deal 512ci, 11.1.....778hp at 6600rpm.
bob460 is offline
post #19 of 46 (permalink) Old 10-26-2016, 01:33 AM Thread Starter
Quoted: 521 Post(s)
Cheers, Bob
Pad heights are similar though I would have to actually measure.
Yes I saw the post and the link to this post in that thread. Straub has offered no build specs as of yet.
With HYDRAULIC ROLLER LOBES and only 487# open spring pressure a rocker stud girdle and 7/16" pushrods (especially) are overkill. .083" wall 3/8" are fine. If I were to step up to the next largest hydraulic roller I have in my catalog I might opt for .120" wall 3/8" pushrods. If you look at the pushrod holes in the AFR castings... a 7/16" push rod is going to be a tough fit I promise you.
Would a stud girdle help stabilize the rocker studs and maybe make a few hp? Yes however I do not have clearance in the LTD for tall valve covers...
This is a simple hydraulic roller lobe street build that just happens to make really good power. The RPM and spring pressures are street friendly and not hard on parts. No need to complicate things. My build philosophy does not sanction the use of .750" lift solid rollers in street engines like has been argued for by a reader on our FB page.
PaGreenCat likes this.
post #20 of 46 (permalink) Old 10-26-2016, 06:44 AM
bob460's Avatar
Quoted: 216 Post(s)
I like the KISS rule aswell, thanks for sharing, not many go indepth like you do and show details with pics,
Here is a basic rundown from the other build......i was surprised at the timing!!
BBF 512 with 11 to 1 Compression
Box stock AFR300 heads
AFR Intake
1050 Carb
Straub Solid Roller custom 260 duration
Morel Needle bearing lifter
7/16" Pushrods
Goal was 700HP
Torque
3600 699.3#/ft
5000 738#/ft Peak Torque
5700 698#/ft
HP
5000 rpm 703HP (Breaks 700)
6500/6600 773.2
36 degrees of timing
Mix of 91 octane and 110
bob460 is offline
post #21 of 46 (permalink) Old 10-26-2016, 12:27 PM Thread Starter
Quoted: 521 Post(s)
AFR Intake
1050 Carb
7/16" Pushrods
Goal was 700HP
Torque
3600 699.3#/ft
5700 698#/ft
HP
6500/6600 773.2
I go into depth to allow for context and comparison.
I am following the other thread as well as it has a link to this thread.
The early evidence more than suggests the castings are capable performers.
post #22 of 46 (permalink) Old 10-27-2016, 09:21 PM
DJOHAGIN's Avatar
Quoted: 8 Post(s)
Scott,
If you where to compare the off-idle torque and throttle response in comparison to a 460 with stock ported heads, Performer intake, 750 Holley, headers, 10 to 1 compression and a [email protected] cam, would this build with a single plane intake have equal or better performance down at the low-end?
Thanks,
Dave
DJOHAGIN is offline
post #23 of 46 (permalink) Old 10-27-2016, 09:44 PM
1972Mach1's Avatar
Quoted: 36 Post(s)
Great build Scott. Thanks for sharing. I know intake gaskets and especially time aren't free, but I second or third the idea that I'd love to see a torker II dyno on the engine.
Lucas
1972Mach1 is offline
post #24 of 46 (permalink) Old 10-28-2016, 06:29 PM
Quoted: 8 Post(s)
Originally Posted by The Mad Porter View Post
This is our long awaited AFR 300 bullitt headed stroker build. We will be using the heads and intake as delivered for a baseline.
557 for Project 12.99 LTD (750+ HP @ 6,100)
By design this build was meant to have the same power-band and peaks as the current 460 as well as the same DCR.
4 bolt CJ D0VE-A block bored and deck plate honed.
Main line honed.
Scat 9000 4.5" crank
Scat 6.7" H beams with 8740 bolts.
Autotec custom AFR pistons 22 cc dish
11.7 to 1 static c/r 9.2 to 1 DCR. Pump gas 92/93 friendly.
External balance due to 6,000 rpm peak.
Canton 15-764 road race pan
Canton 15-763 pick up for M84 D HFD (paul kane) oil pump.
AFR Bullitt 300 cylinder heads
Comp Ultra pro magnum XD rockers 1.80
AFR Dominator flange intake
Comp carbs 1050 3 circuit street dominator.
Engine pro billet timing set with thrust bearing.
Custom comp roller 3 pattern HR cam 252-254 / 266 @ .050" 110 Lsa 106 Icl
Comp 936 16 solid roller lifters
Smith brothers push rods. 3/8" Length TBD.
Comp cams Ultra Pro Magnum 1.8 rockers.
New Engine quest timing cover
Performance Quotient Aluminum Water pump.
80008 Professional products Damper
OEM hatchet
D/S distributor with bronze gear.
Blue thunder CJ valve covers
Targeted output.
700 Tq
680 to 700 HP at a street friendly 6000 rpm
Actual output
736 TQ
755 HP @ 6,100 rpm with 2 1/4" dyno headers
733 Tq
744 HP @ 5,900 rpm with 2" dyno headers
I felt that the dyno correction factor was 2% too high so I corrected to what I feel are more realistic numbers based on weather conditions.
The combo made a best pull of 729.7 HP UNCORRECTED.
See our FB link in signature line for more pics and dyno vids.
Mad Porter...Is this type of Motor for Sale and if so how much are we talking about to purchase such engines.
Sent from my SM-G935V using Tapatalk
www.betterdeadth is offline
post #25 of 46 (permalink) Old 10-28-2016, 07:20 PM Thread Starter
Quoted: 521 Post(s)
Yes this will be added to our current list of crate engine options. I have the pieces to duplicate this combo including the 4 bolt main CJ D0VE block.
Telephone me at the contact number in my signature line or email me at: [email protected]
post #26 of 46 (permalink) Old 10-28-2016, 07:23 PM
Quoted: 8 Post(s)
Do you by chance have any experience building stroker motors tht have roots style blowers.
post #27 of 46 (permalink) Old 10-28-2016, 08:33 PM Thread Starter
Quoted: 521 Post(s)
Originally Posted by DJOHAGIN View Post
Scott,
Thanks,
Dave
Dave,
Given that the engine was designed to duplicate the 460 currently in the LTD its off idle and tip in characteristics are similar to this engine. The additional duration and resultent overlap keeps this engine kind of snarkey until about 1,500 rpm. Throttle response on the dyno was excellent.
To your question.
The comparison you reference is almost exactly like our 460 HP crate engine with a HP peak of 5000 rpm with a torque peak of 3,400 rpm. This type of combo will be a bit better with regard to low speed manners than either the LTD's current 460 or the 557.
The whole point with this combo is to have a street friendly RPM range and reasonably good driveability with the comp carbs 3 circuit street dominator. With the 3450+ stall convertor and 3.50 gears I expect after some tuning with a wideband that the 557 will be a blast bordering on off the hook to drive.
I intentionally left the engine a bit LEAN on the dyno to do final A/F tuning in the vehicle which IMO is more accurate. I believe there are a few more HP hiding in the combo.
post #28 of 46 (permalink) Old 10-28-2016, 08:36 PM Thread Starter
Quoted: 521 Post(s)
Email received and answered.
post #29 of 46 (permalink) Old 07-03-2018, 03:12 PM
Quoted: 7 Post(s)
Just ran into this thread! Thank you & good work!!!
DAMAGEinc
nedceifus is offline
post #30 of 46 (permalink) Old 07-03-2018, 05:29 PM Thread Starter
Quoted: 521 Post(s)
Thank you,
After splitting the number 5 cylinder (even with a good sonic check) we upgraded to an A460 block and a bit more HR cam timing for 829 HP
https://www.facebook.com/pg/PpamLLC/...44764065901276
