460 with d2ve heads - 460 Ford Forum
 1Likes
  • 1 Post By Smactek
post #1 of 5 (permalink) Old 03-31-2018, 12:54 AM Thread Starter
460 with d2ve heads
I'm trying to get my mud truck running again on a tight budget ( about $1500). The plan is to use a d1 block, stock crank, cj rods, I have d2ve heads (I already know they are not very good) and cast intake. I need to build a solid short block and can upgrade top end later down the road. The engine is a pain to pull out. The truck is almost 10,000 pounds and tires are about 56" tall. I have a 4 speed manual transmission with a 5 speed transfer case so I can have almost any gear I want. I'm wanting a good healthy engine, reliability is most important. The truck is just a toy, no competition. Want to use pump was. Will probably bore .030 over What cam and pistons should I use?
Sent from my Moto Z (2) using Tapatalk
95boots is offline
post #2 of 5 (permalink) Old 04-01-2018, 12:33 PM
Quoted: 15 Post(s)
as tough as that may be to R&I the engine. At least a set of D3ve heads, may be a good, inexpensive, addition to your base build. They can be found on 100's of Fords at any pick and pull. The Mad Porter is a fantastic resource, for a very reasonably priced Cam, ground to your needs.
DanE likes this.
524 CID. 4.3 x 4.400, D20E Heads per Reincarnation Illustrations, 10.5 to 1, Icon & Scat Forgings. in a Hondo Pantera Jet.
Smactek is offline
post #3 of 5 (permalink) Old 04-16-2018, 10:38 PM Thread Starter
I was lucky enough to find a set of c8ve heads. That was after I my block was assembled with a set of speed pro flat top forged pistons. This should put my CR at 11.5-12:1.
95boots is offline
post #4 of 5 (permalink) Old 04-17-2018, 10:34 AM
Quoted: 185 Post(s)
You'll have to use at least some racing gasoline but other than that and the differences in the valvetrain it should work fine.
Dave McLain
McLain's Automotive
DaveMcLain is offline
post #5 of 5 (permalink) Old 04-17-2018, 10:36 AM Thread Starter
Ya I was planning on that or looking into e85. It is at a lost of gas stations around me.
95boots is offline
