521 bbf updates - 460 Ford Forum
 6Likes
post #1 of 44 (permalink) Old 05-03-2018, 12:54 PM Thread Starter
Quoted: 9 Post(s)
521 bbf updates
Hi, I have a 521 bbf crate engine, all original with a powerglide in a 84 ford Thunderbird and Im running low 10īs and I want to get lower, around 9.70
I am going to send the engine for a refresh, it has around 200 runs, and they recommend me to change crank, rods and pistons, and maybe even cam and intake to make it a 557 but I think that it would be too expensive.
So I wanted to ask you if you think that it would be enough with a blueprint, porting heads and intake and maybe changing the cam? And do you think it would just as expensive as the first option or a lot cheaper?
george1987 is offline
post #2 of 44 (permalink) Old 05-03-2018, 01:33 PM
CarsByCarl's Avatar
Quoted: 185 Post(s)
I am going to send the engine for a refresh, it has around 200 runs, and they recommend me to change crank, rods and pistons, and maybe even cam and intake but I think that it would be too expensive.
So I wanted to ask you if you think that it would be enough with a blueprint, porting heads and intake and maybe changing the cam? Do you think it would just as expensive as the first option or a lot cheaper?
Leave the bottom end alone, and bolt on AFR heads and intake.
CarsByCarl is offline
post #3 of 44 (permalink) Old 05-03-2018, 02:27 PM
68galaxie500's Avatar
What heads and intake are already on the engine?
What pistons and connecting rods?
What cam?
More details about the 521 will help with more constructive comments.
There is probably alot of room for improvement with what you already have.
Suggesting AFR heads and intake - and pistons (with correct valve reliefs) etc.. will be spendy.
Of course there are a few AFR proponents here wanting to spend others money
Cheers
68galaxie500 is offline
post #4 of 44 (permalink) Old 05-03-2018, 02:52 PM Thread Starter
Quoted: 9 Post(s)
thank you for your comments, here are more details of the engine:
-HP (SAE J607) 609 hp @ 5750 rpm
-Torque (SAE J607) 630 lb-ft of torque @ 4500 rpm
-HP (SAE 1349 Corrected) 580 hp @ 5750 rpm
-Torque (SAE 1349 Corrected) 600 lb-ft of torque @ 4500 rpm
-10.0:1 compression ratio Cast nodular iron crankshaft, M-6303-A514Victor single plane intake manifold M-9424-H429
-Ford Racing "Super Cobra Jet" aluminum cylinder heads. They flow significantly more than production 460 heads. Combustion chamber volume is 72cc (nominal)
-Ford Racing "Super Cobra Jet" valve train includes dual-valve springs, retainers, keepers, seals and premium stainless steel swirl polished valves. Intake valve diameter is 2.20" and exhaust valve diameter is 1.76"
-Ford Racing high-performance solid roller mechanical camshaft M-6250-A514 provides significant horsepower increases above 3500 RPM and good low-end torque. Valve lift is .640" intake and exhaust. Duration at .050" is 254 degrees intake and 258 degrees exhaust
-Ford Racing forged aluminum dished pistons, bore size 4.390"
post #5 of 44 (permalink) Old 05-03-2018, 03:41 PM
CarsByCarl's Avatar
Quoted: 185 Post(s)
AFR heads and intake will bolt right up. No need to notch the pistons with that cam. Should be worth about 70HP. ~$2500.00 for heads and intake, sell the ones you have....$1000 out of pocket tops, with minimal headaches for 70+HP. No other changes are going to come close to that level of power increase per dollar. Change out the cam, and you could easily be looking at a 100+HP improvement.
bob460 likes this.
post #6 of 44 (permalink) Old 05-03-2018, 03:55 PM
Quoted: 132 Post(s)
I believe Carl is right. Tear down the engine to check it over, check clearances. I’m sure it is ok, put new bearings, afr heads and intake, and cam. Your cheapest way to get what you want.
Having a shop build you a 557 is gonna cost a fortune. Just to balance the big strokers can get expensive sometimes. Sounds like a fun little ride. Best of luck in your choice.
I’ve had several qualified sources explain to me how superior the afr heads are. Trust in them.
I’ve yet to run my engine yet, but it is getting close and I’m more than ecstatic about it.
Fordman1971 is offline
post #7 of 44 (permalink) Old 05-03-2018, 06:19 PM Thread Starter
Quoted: 9 Post(s)
the AFR heads are better than the P51 Kaase? I have seen a lot of people talking good things about the kaase.
Other thing, what do you think about carb spacers? do you recommend them?
thank you
post #8 of 44 (permalink) Old 05-03-2018, 07:18 PM
Colt's Avatar
Quoted: 98 Post(s)
What cam?
Cheers
This post needs a "LIKE" button!!!!
Project "Indigestion" 1964 Fairlane BBF
Colt is offline
post #9 of 44 (permalink) Old 05-03-2018, 07:19 PM
Quoted: 510 Post(s)
thank you
Out of the box with no port work P-51's vs AFR 295 or 315's... The AFR's will win.
P-51's with a 2.300" intake valve and port work will run with the AFR 315's.
AFR heads have already made over 1000 hp with out of the box 315 and AFR dommy intake.
bob460 likes this.
post #10 of 44 (permalink) Old 05-03-2018, 07:53 PM
bob460's Avatar
Quoted: 215 Post(s)
What's your budget for this freshen up?
What is the car weight?
What size stall converter?
What rear gears?
Cheers, Bob
bob460 is offline
post #11 of 44 (permalink) Old 05-03-2018, 08:22 PM
CarsByCarl's Avatar
Quoted: 185 Post(s)
Yes.
post #12 of 44 (permalink) Old 05-03-2018, 09:29 PM
It is almost comical how a few on here want everyone to buy AFR heads.
I like the new AFR heads, However - the SCJ heads with a little work can make big power too.
You can easily make 100 more HP with what you already have - without the HUGE expense of AFR heads, intake manifold, piston modifications, etc.....
A good valve job with back cut intake valves will yield BIG gains with the SCJ heads.
A custom cam will also add to the power output.
Ported intake will also help. Not sure what carb you are running - 1050 dominator minimum.
Good luck!!
like I said, AFR are decent heads. But SCJ heads are not all that bad either. And with a little work on the SCJ heads and a custom cam you will see a very easy 100 HP increase. And not be spending $2500++ on the shiny new AFR heads.
post #13 of 44 (permalink) Old 05-03-2018, 09:34 PM
Another 521 example.
Same camshaft your crate engine has.
The difference is ported SCJ heads.
Result: super flat power curve, 668 hp and 676 ft lb torque.
Add a custom cam and you are well into the 700+ HP region.
521 Pump Gas build "Honey Bunny"
Cheers
post #14 of 44 (permalink) Old 05-04-2018, 09:43 AM
CarsByCarl's Avatar
Quoted: 185 Post(s)
Nobody said SCJ heads aren't decent heads, or that they can't make good power, but....
Valvejobs aren't free
Replacing worn valve-springs, guides, etc. isn't free
Quality port work certainly isn't free
Transporting parts to and from people isn't free
The hassle of coordinating all those efforts, and the time involved is something to consider. I find it unlikely that there's anything to be saved by jumping through all the hoops to make SCJ heads perform, and no matter how much you rub on them, they're not going to perform as well as the AFR's, at least not without a custom manifold, and spending far in excess of what you would by bolting on a better set of heads.
If the OP prefers to jump through all the hoops to get more performance out of his SCJ's, that's fine. I was just presenting an option that faster/easier/better, and probably cheaper.
Fordman1971 likes this.
post #15 of 44 (permalink) Old 05-04-2018, 11:43 AM Thread Starter
Quoted: 9 Post(s)
Ive been looking at the AFR heads and I think its the easiest and faster option and maybe cheapier if I can sell the scj in a short time.
How much do you think it would be for porting heads and manifold in the cnc? around $2000? and how much for a custom cam?
