No oil pressure? - 460 Ford Forum
 3Likes
post #1 of 28 (permalink) Old 08-09-2018, 01:16 PM Thread Starter
No oil pressure?
Ok, this topic is already here a million times...but, I changed the oil and filter in the jet boat. Everything was as it should be before. Now I have no oil pressure. Checked the sending unit with the ohm meter, good. Checked the electric gage with key on and tapping wire to ground, works. Tried another sending unit, still doesn't work. Checked to make sure oil was in the filter, yes. Replaced the filter, still doesn't work. Pulled the distributor and checked the drive shaft, good. Ran the pump with a drill, gage didn't work but there was resistance showing it could be pumping.
I noticed that there is no sign of oil when I pulled the sending unit? I have not yet pulled the valve covers to check for oiling to the rockers.
Everything is low hours, about 30. Ford hi volume pump, new Stewart Warner gage and matching sending unit, oil is full.
Any ideas as to why I'm not seeing oil at the sending unit?
84_crusader is offline
post #2 of 28 (permalink) Old 08-09-2018, 01:20 PM
John F.'s Avatar
Quoted: 19 Post(s)
Do you have a remote oil filter set up? Sometimes the connecting hoses may get switched and this will cause a problem with the check ball system.
1956 Ford F100...466/C6, Edelbrock aluminum heads and Preformer intake w/750cfm carb, Comp. cam , H/S roller rockers, MSD lighter, KB flat top pistons, Currie rear end, B & M shifter, tubbed, Ididit column
John F. is offline
post #3 of 28 (permalink) Old 08-09-2018, 01:51 PM Thread Starter
Yes I do, it is in excellent condition and correctly installed. I have been running this set up since the beginning of last year.
post #4 of 28 (permalink) Old 08-09-2018, 02:50 PM
Quoted: 39 Post(s)
Fram?
slowride is offline
post #5 of 28 (permalink) Old 08-09-2018, 02:56 PM Thread Starter
Beat up Fram all you want. No, it was a micro guard then replaced with a fram. It's not the filter
Originally Posted by slowride View Post
Fram?
post #6 of 28 (permalink) Old 08-09-2018, 03:11 PM
Quoted: 39 Post(s)
Not beating them up, their reputation is deserved. I work for an OEM and Fram's were killing our engines due to the bypass construction and paper end caps collapsing. I've cut them apart and compared construction. I don't like orange so much that I won't run Wix or Purolator.
DanE likes this.
slowride is offline
post #7 of 28 (permalink) Old 08-09-2018, 03:24 PM Thread Starter
Unless I got 2 bad filters in a row from 2 different manufacturers i don't see how it could be the filter.
post #8 of 28 (permalink) Old 08-09-2018, 03:27 PM
Quoted: 39 Post(s)
Highly unlikely and the Fram probably isn't the issue this time. Was just asking as your condition is exactly what Frams were causing in our engines.
slowride is offline
post #9 of 28 (permalink) Old 08-09-2018, 03:30 PM Thread Starter
I wish it was the filter, that was my first try. I'm assuming somehow oil is not reaching the sender. But why?
post #10 of 28 (permalink) Old 08-09-2018, 10:50 PM
Quoted: 184 Post(s)
why not get a real gauge
BUY,SELL, or TRADE BBF parts
Dynoed or Test STAND RAN
CYLINDER HEAD PORTING
HEAD FLOWING
PRO SYSTEMS CARBS
BOSS 302 351 429 800CI+
BOSS 429 is offline
post #11 of 28 (permalink) Old 08-10-2018, 10:41 AM Thread Starter
As in a mechanical gage? It's in a boat and I'm not running 20+ feet of oil line to the gage. There's nothing wrong with electric.
post #12 of 28 (permalink) Old 08-10-2018, 10:42 AM
Quoted: 184 Post(s)
to test it.
HEAD FLOWING
PRO SYSTEMS CARBS
BOSS 429 is offline
post #13 of 28 (permalink) Old 08-10-2018, 10:47 AM Thread Starter
As I believe I stated already there is no sign of oil at the sender location. For unknown reason oil does not seem to be reaching the sending unit after the oil change.
to test it.
post #14 of 28 (permalink) Old 08-10-2018, 10:48 AM Thread Starter
I will give it a try though. I think I'll try the sender location by the fuel pump also.
to test it.
post #15 of 28 (permalink) Old 08-10-2018, 11:04 AM
Quoted: 184 Post(s)
no, it belongs in the rear of a oem 460/429 block
HEAD FLOWING
PRO SYSTEMS CARBS
BOSS 429 is offline
