460 wont rev past 5400rpm - 460 Ford Forum
 4Likes
post #1 of 26 (permalink) Old 09-04-2018, 10:14 AM Thread Starter
aftershock45's Avatar
Quoted: 8 Post(s)
ok guys, I will start out with the engine combination as i know every one wants to know that first, Its based off the 500hp engine in the hp chart, 30over 460 with 9-1, trick flow power port 290heads with 120lb springs, it has the 274xe cam, msd probillet dist, blaster 2coil, 6al ignition, holley blue pump, 850holley, running inital timing at 17 and full at 36. so engine wont rev past 5400rpm and almost seems like its hitting the rev limiter but its a lot more aggressive and engine will loose rpm and pop and miss. if i lower rev limiter to 5300 it comes up on the limiter fine and if i raise limiter higher were it would never hit it still misses and pops.so things i have tried so far, changed coil, changed plug wires, tried another msd box,checked that i am getting lots of fuel even swaped another pump i had,changed plugs and narrowed gap from .45-.35, swapped holley 850 to a 750 edelbrock, checked rocker arms didnt find any loose and reset to 1/2turn preload. Im not sure if its a ignition problem or valve float. I have a hard time believing its valve float as their brand new heads and springs. Only thing i haven't changed is the cap and
rotor and i cant see the pickup causing any problems as it ohmed fine.
aftershock45 is online now
post #2 of 26 (permalink) Old 09-04-2018, 11:47 AM
Quoted: 497 Post(s)
Before installing the heads did you check spring installed height, seat pressure and open pressures?
BOSS 429 likes this.
post #3 of 26 (permalink) Old 09-04-2018, 12:03 PM Thread Starter
Quoted: 8 Post(s)
I don't have the tools to test them, all i did was pull the inner springs out for cam break in, and reinstall them after break in. I was hoping a out the box head would be good enough not to have to screw with for my power levels
post #4 of 26 (permalink) Old 09-04-2018, 01:31 PM
Quoted: 497 Post(s)
It is up to the end user to make sure the parts are suitable. This sounds like a spring issue. I would remove a valve spring and have it checked for seat and open at the installed height.
post #5 of 26 (permalink) Old 09-04-2018, 02:05 PM Thread Starter
Quoted: 8 Post(s)
[QUOTE=The Mad Porter;1656763]It is up to the end user to make sure the parts are suitable. This sounds like a spring issue. I would remove a valve spring and have it checked for seat and open at the installed height.
S[/QUOTE
would a on engine spring tester work to see if springs are bad, like proform 67597. could any thing else cause this? I was a little worried that maybe the cam is going flat but seem to run fine, valves never had any loose rockers and cant hear any noise from valve train but is hard to tell with the puller headers. i didnt have this problem right after break in seemed to rev up fine, had alot of problems with a off idle stumble and getting the timing curve were it needed to be. The only thing that happened was while i was checking total timing the throtle cable stuck the throttle and it ran on the limiter for a few seconds before i got it shut off, would this damage the valve springs?
post #6 of 26 (permalink) Old 09-04-2018, 02:31 PM
[quote=aftershock45;1656765]
S[/QUOTE
Bent pushrod(s)?
1973 Mustang Convertible
TommyK is offline
post #7 of 26 (permalink) Old 09-04-2018, 03:26 PM
CarsByCarl's Avatar
Quoted: 185 Post(s)
You don't necessarily need a spring tester. Just measure the installed height and calculate the pressures, coil bind clearance, etc. based on the specs published for the springs.
CarsByCarl is offline
post #8 of 26 (permalink) Old 09-04-2018, 04:47 PM Thread Starter
Quoted: 8 Post(s)
[quote=TommyK;1656767]
Bent pushrod(s)?
their 3/8 chromoly, i didnt take them out but didnt look bent when i set rockers, i would imagine if any were bent it would of made rocker arms loose
post #9 of 26 (permalink) Old 09-04-2018, 04:55 PM Thread Starter
Quoted: 8 Post(s)
but how would that tell me if the springs were bad? the only thing that would do is check that the installed height is right.
post #10 of 26 (permalink) Old 09-04-2018, 05:04 PM Thread Starter
Quoted: 8 Post(s)
the trick flow spring specs are 120lbs @ 1.950" installed height, 394 lbs @1.175" open, 390lb per inch spring rate. The springs recommended for cam are 112lbs @ 1.950 installed height, 355lbs @ 1.175, 347lbs per inch rate, i dont see this being a problem as long as the trick flow springs are installed at the right height.
post #11 of 26 (permalink) Old 09-04-2018, 05:43 PM
CarsByCarl's Avatar
Quoted: 185 Post(s)
With the actual physical installed height, specs on the spring, and actual lift at the valve, you can calculate the actual pressures on the seat and over the nose, and also calculate spring bind clearance. Of course none of that will tell you if you have a damaged spring, but it will tell you if your pressures are correct or possibly causing a problem.
For example:
If your actual installed height is 1.85, and your cam has .600 lift, your pressures are going to be 159/393 which is way too much and may have damaged the cam and/or lifters.
If your actual installed height is 2.05, and your cam has .550 lift, your pressures are going to be 81/295 which is too low, and may be causing valve bounce on the seat.
All this stuff has to be checked and verified any time an engine is built. There is no "close enough", or assuming that it's fine.
The Mad Porter likes this.
post #12 of 26 (permalink) Old 09-04-2018, 05:54 PM Thread Starter
Quoted: 8 Post(s)
For example:
first engine i have ever built so their has been a bit of a learning curve, i guess checking my installed height and spring seat and open pressure are the next things i will check
CarsByCarl likes this.
post #13 of 26 (permalink) Old 09-05-2018, 09:15 AM Thread Starter
Quoted: 8 Post(s)
So i have ordered some tools to check spring height and pressure, The only thing im wondering is if the installed height and pressures are accurate to the trick flow specs, are they close enough to what the cam recommends or should i buy the comp springs that are recommended.
post #14 of 26 (permalink) Old 04-15-2019, 08:11 PM Thread Starter
Quoted: 8 Post(s)
So now that winter is almost over its time to start working on this thing again, I checked the seat pressure on the springs and they all checked fine,Next thing i checked was to see if i wore a lob on the cam so i used a dial indicator to check the valve lift and i was sure it had wore lobs (pretty difficult to measure hyd flat tappet lift with lifter bleed off). Pulled lifters and found no wear on lifters and cam, but found that my cam bearings were bad, and with further investigation i found that i had internal wear on the lifters at the pushrod oil metering valves. So long story short im in the process of rebuilding the engine with a new cam shaft, becided this time to go with a solid roller camshaft and matching springs. Camshaft is a lunati voodo 640/650 lift duration 261/267 110 separation, Im also looking to deck the block to increase cr and help with quench, the block is a d9 with 10.322 deck height and im using speedpro h418p piston (1.752 compression height) i am planning to stay .005 in the hole with .040 head gasket which will give me .045 quench and right around 10-1 compression, will i have enough piston to valve clearance with the tfs heads?
post #15 of 26 (permalink) Old 04-15-2019, 08:52 PM
Quoted: 497 Post(s)
The valve notch in the 418 pistons is for the std size valve. You had better address the radial issue.
SJ
