460 efi intake on 429 with DOVE heads - 460 Ford Forum
 1Likes
  • 1 Post By BigBlockRanger
post #1 of 7 (permalink) Old 01-19-2019, 08:50 PM Thread Starter
Epyon's Avatar
I need to know what to do to use just the efi intake on my engine . It's a 71 Thunerbird . BOSS 429 did it , but did not give any info on doing it . If it is a certin year intake and or gasket , please let me know .
Monsters are real , how else do you explain my cars .
Epyon is offline
post #2 of 7 (permalink) Old 01-21-2019, 01:10 PM
Odis Laird is offline
post #3 of 7 (permalink) Old 01-21-2019, 03:32 PM
If you are trying to use a factory EFI intake with the DOVE's it won't work. the EFI heads are different, so the intake won't match up. There are aftermarket intakes that will work with the Holley EFI system. If you need injector holes in the intake you can have them welded in or just use one of the bolt on EFI systems that has the injectors in the throttle body. Hope this helps.
jeffgfg is offline
post #4 of 7 (permalink) Old 01-25-2019, 01:41 PM
BigBlockRanger's Avatar
Quoted: 21 Post(s)
He stated he has done several and I've seen the pic of the later model intake on the old style heads.
Have you tried contacting him?
BOSS 429 likes this.
'83 Mustang GT - 552/C6 - 10.12 @ 136
'73 "F100" - EFI460/E4OD
Drag Week 2014 - *kapooya*
BigBlockRanger is offline
post #5 of 7 (permalink) Old 01-26-2019, 06:50 PM
Quoted: 178 Post(s)
Yup we finally talked,he should be good to go right now
-R
BUY,SELL, or TRADE BBF parts
Dynoed or Test STAND RAN
CYLINDER HEAD PORTING
HEAD FLOWING
PRO SYSTEMS CARBS
BOSS 302 351 429 800CI+
BOSS 429 is offline
post #6 of 7 (permalink) Old 02-21-2019, 10:34 PM Thread Starter
Epyon's Avatar
Ok
The gaskets did not match the ports . The head ports had meat to grind and weld up , but that would be way to much work (for right now). I had the intake and and gaskets for both efi intake and dove heads . I will be using the efi heads an intake on another car .
Epyon is offline
post #7 of 7 (permalink) Old 02-22-2019, 12:27 PM
Quoted: 178 Post(s)
your phone wont go thru? have to call me in the am
-Rich
do a search on here you can see some of the ones I have done, sometimes the search button doesnt work too well tho
HEAD FLOWING
PRO SYSTEMS CARBS
BOSS 429 is offline
