quick-fuel carb problem on a 460 - 460 Ford Forum
post #1 of 7 (permalink) Old 02-17-2019, 06:58 AM Thread Starter
new guy here, building a '53 F-100 with a 460 and got carb problems
1975 460ci from Lincoln Mark IV
Smog head but thermactor hump removed and exh ports smoothed
Drilled for 7/16 studs and using 1:73 roller tip rockers
Heads decked to flat
Fed Mogal H535P flat top pistons
Comp 252 cam
Comp ration 9:1 calculated
Edelbrock 1726 fuel pump 3/8 line 7-8# fuel pressure read on gauge at carb
Quick fuel hr-780 4 barrel vacumn secondaries
Edelbrock performer intake
On the first start, carb flooding…floats set too high… corrected.......Now have fuel dripping from venturies into throat…Can’t seem to get it stopped. Checked needle and seat and it's all clear and working properly. Float not full of gas. Carb rebuilt for this install by a competent carb shop but engine has been idle for a few years.
Engine runs smooth with quick throttle response, no hesitation
But something is making fuel leak and we can’t find it
John Niolon is offline
post #2 of 7 (permalink) Old 02-17-2019, 07:29 AM
Quoted: 9 Post(s)
John, set your idle mix screws to 1-1/2 turns out to start. Check to see if throttle blades are above transfer slot. If so it will dribble fuel from booster. Verify pv is not blown as well. Good luck cory
2 wicked is offline
post #3 of 7 (permalink) Old 02-17-2019, 08:19 AM
aquartlow's Avatar
Quoted: 24 Post(s)
X2 on checking power valve and I have seen brand new needle/seat assemblies not work or seal well. May also want to try lowering float levels about 1/2 to 1 full turn on the needle/seat assembly(have fuel barely dribble from site screw hole while bumping the vehicle), pressure is a bit on the high side, 6.5-7 psi is usually "good enough" for a "Holley" type of carb. Make sure air bleeds are clear, could also be a metering gasket issue causing partial blocking of the main body to metering block air bleed passages. Hope this helps.
www.supermotors.net/22468
Yeah, it's a hybrid...It burns gas and tires.
No matter how good she looks somebody, somewhere is tired of her sh#t.
aquartlow is online now
post #4 of 7 (permalink) Old 02-17-2019, 08:49 AM
Quoted: 178 Post(s)
Comp 252 cam
If its dripping still then either floats are still too high,or neededls are bad ,and need replaced. whats the fuel presser?
BUY,SELL, or TRADE BBF parts
Dynoed or Test STAND RAN
CYLINDER HEAD PORTING
HEAD FLOWING
PRO SYSTEMS CARBS
BOSS 302 351 429 800CI+
BOSS 429 is offline
post #5 of 7 (permalink) Old 02-17-2019, 01:45 PM Thread Starter
gauge at carb reads 7-8#s
post #6 of 7 (permalink) Old 02-17-2019, 03:32 PM
Quoted: 495 Post(s)
Cam specs?
Idle speed?
Initial timing? Total timing? What RPM?
SJ
The Mad Porter is online now
post #7 of 7 (permalink) Old 02-17-2019, 03:52 PM Thread Starter
Originally Posted by The Mad Porter View Post
Cam specs?
Idle speed?
SJ
Truck is 1953 F-100 project.. not on road yet. this was the first start on the engine since initial break-in period a few years ago.
Comp 252 cam
rpm range 800-4800
lobe seperation 110
intake centerline 106
duration 252 In & ex
duration at .050 lift 206 in & ex
valve lift 468 in & ex
lobe lift .272 in & ex
Init timing 10 degrees
Perf Distributor HEI adds at least 15 degrees on acceleration (their spec)
Edelbrock 1726 fuel pump 3/8 line 7-8# fuel pressure on gauge at carb
Quick fuel hr-780 4 barrel vacumn secondaries EDIT carb is actually a HR650 with mech secondaries
see edit aboved HR650 is true. had a heck of a time finding list #
First start, carb flooding…floats set too high… corrected ...now the top of floats now level with bottom of site glass
Now have fuel dripping from venturies or boosters into throat… (hard to tell)
Open to any suggestions
john
Quick fuel vs Quick fuel Super snake Steve Engine Tech 8 11-03-2014 02:48 PM
"NEW" Quick Fuel 1050 carb !! Nitro Lew The Auction Block 10 06-11-2008 06:04 PM
Quick fuel or Jet Carb uf63 Chilly's Garage 7 05-21-2008 11:19 PM
float level on a Quick fuel carb ? bigblock79 Engine Tech 2 04-30-2007 05:22 PM
Anyone running a Quick Fuel Carb? mgt351 Engine Tech 7 04-20-2007 10:16 PM
