P-51 inlet gaskets? - 460 Ford Forum
post #1 of 4 (permalink) Old 03-07-2019, 03:44 PM Thread Starter
fabphil's Avatar
P-51 inlet gaskets?
I have a pair of P-51 heads. I've just laid the blue Fel-Pro inlet gasket on the head and the head port is almost the width of the whole gasket. The gasket has approx. 1/8" over lap of the port. If trimmed there would be no gasket left!
What do you guys use for inlet gaskets?
You have to get older, but you don't have to grow up
fabphil is offline
post #2 of 4 (permalink) Old 03-07-2019, 07:05 PM
Quoted: 184 Post(s)
1231 FEL PRO
BUY,SELL, or TRADE BBF parts
Dynoed or Test STAND RAN
CYLINDER HEAD PORTING
HEAD FLOWING
PRO SYSTEMS CARBS
BOSS 302 351 429 800CI+
BOSS 429 is offline
post #3 of 4 (permalink) Old 03-08-2019, 03:09 AM Thread Starter
fabphil's Avatar
Many thanks. Just checked the part number at Summit and they look completely different from the gaskets packed in the 460 gasket set by Fel-Pro.
Will get a set ordered.
fabphil is offline
post #4 of 4 (permalink) Old 03-08-2019, 03:23 AM
Quoted: 43 Post(s)
The Felpro gasket set will be for small port heads. Most likely a blue gasket ?
gregaust is offline
water inlet needed for inbetween hoses mustangsrus803 The Auction Block 1 05-02-2009 12:55 PM
WTB - Holley dual inlet front bowl tall69 The Auction Block 2 03-27-2009 08:50 PM
weiand stealth inlet manifold questions mr_xa460 Engine Tech 9 05-05-2008 04:59 PM
Air Filter w/ Fresh Air Inlet Provisions? 1959Ford Engine Tech 2 07-01-2007 04:01 PM
Lem, inlet valves solved the problem Fairlane62 Engine Tech 4 01-12-2006 07:34 PM
