521, P-51 heads. Cam/intake/carb advice - 460 Ford Forum
 1Likes
post #1 of 20 (permalink) Old 03-26-2019, 06:14 PM Thread Starter
Hey! First time posting and I have a few questions.
Here is what I know:
1. Intended use - Street/Strip cruiser
2. Vehicle info (weight/gearing/trans) - 66 f100 short bed, ~3700lbs, 3.90, C6 with 3200-3500 stall
3. Fuel desired to use - Pump gas, best we have in Midland Tx is 91 octane
4. Parts you already have - 521 FRPP stroker kit - 4.390 bore/4.30 stroke, 28cc dish pistons. Block is zero decked. Kaase P-51 heads. I have not ordered head gaskets yet so compression can be between 10.5:1 to 11:1. 1.73 rockers.
5. Proposed budget - $3k for all gaskets, arp bolts, oil pump, intake, cam and carburetor.
I called comp cams today about a cam. They recommended a custom grind. Here are the specs:
lift .761/.762
adv duration - 288/300
@50 - 260/268
lobe separation - 112
center line - 108/116
Will this cam work well for my wants and be fun on the street?
What intake and carb do you recommend with this setup? I was originally wanting EFI, but it seems most companies miss that 650-800hp range for their EFI units. I'm ok with a carb, just thought EFI might be nice.
Thanks,
Wesley
W_D_R is offline
post #2 of 20 (permalink) Old 03-26-2019, 09:36 PM
Quoted: 210 Post(s)
Thumbs up
Will it work well YES, want to make it better call KAASE............none better IMO!!
Try the new stealth sniper 4500 efi carb with a mafia intake.
Looks like a fun build.
Cheers, Bob
bob460 is offline
post #3 of 20 (permalink) Old 03-27-2019, 07:50 AM Thread Starter
Thanks Bob!
I called comp yesterday and I called Holley yesterday. I'll give Kaase a call today.
W_D_R is offline
post #4 of 20 (permalink) Old 03-27-2019, 08:11 AM
Quoted: 7 Post(s)
Or get in touch with Scott Johnston aka The Mad Porter. He set me up with a set up very similar to yours and it was exactly what I wanted.
StephenW is offline
post #5 of 20 (permalink) Old 03-27-2019, 11:57 AM
Quoted: 489 Post(s)
How much street time is this combo going to see?
Aggressive solid roller lobes and the required spring pressures are hell on lifters. A quality bushed roller lifter is a great idea.
SJ
used 2b RHP
The Mad Porter is online now
post #6 of 20 (permalink) Old 03-27-2019, 12:21 PM Thread Starter
It will probably only see street time. Friday night dinners and Saturday car shows/meets. I'm open to suggestions!
W_D_R is offline
post #7 of 20 (permalink) Old 03-27-2019, 03:18 PM
cletus66's Avatar
Quoted: 27 Post(s)
Is the rotating assembly new enough that the valve reliefs in the pistons match the heads?
cletus66 is offline
post #8 of 20 (permalink) Old 03-27-2019, 10:10 PM
Quoted: 210 Post(s)
SJ
used 2b RHP
This might be a great build choice to use the comp dual conical valve springs........and a .904 lifter upgrade aswell.
Cheers, Bob
bob460 is offline
post #9 of 20 (permalink) Old 03-27-2019, 10:19 PM Thread Starter
The rotating assembly and heads were bought at the same time around June of 2012. The p51's had a few months wait. During the wait I bought a new Harley road glide and for the next 4 years I built , rebuilt and rode as often as possible. The heads were delivered to my dads house and I never saw them until a about 2 weeks ago when I decided to put this engine together.
W_D_R is offline
post #10 of 20 (permalink) Old 03-29-2019, 04:14 AM
Quoted: 41 Post(s)
That cam IMO is too much. Look at something like a comp XR292R is a great street cam & would suit your needs and driveline. 254/[email protected] , 671/678
gregaust is offline
post #11 of 20 (permalink) Old 03-30-2019, 12:35 AM
Quoted: 17 Post(s)
I want to see this when it’s done! I have a 66 F100 with work done by Scotty and just love it. I have a video on YouTube if you want the link let me know.
66F100466 is online now
post #12 of 20 (permalink) Old 03-30-2019, 09:58 PM
Quoted: 210 Post(s)
Cam Motion have a custom tight lash solid roller, you choose the duration and any lift you want!!
Cheers, Bob
gregaust likes this.
bob460 is offline
post #13 of 20 (permalink) Old 04-06-2019, 10:04 AM Thread Starter
All the parts are in except the 1050 dominator. It's coming from pro systems. Roger suggested a comp cam. 34-715-9. Today is build day!
W_D_R is offline
post #14 of 20 (permalink) Old 04-06-2019, 01:10 PM
Quoted: 489 Post(s)
That is a good cam for "Drag Race and limited use"
For street use? Keep a close eye on your lifters and lash. On the street the lifters will become a consumable.
You would do well to utilize a quality bushed lifter.
SJ
used 2b RHP
post #15 of 20 (permalink) Old 04-06-2019, 03:11 PM Thread Starter
That's sucks to read. We told him street use. The lifters I'm using are the comp sportsmans. I dont remember if they were bearing or bushed.
W_D_R is offline
P-51 heads,Trickflow Mafia intake, carb 89460fox The Auction Block 27 11-17-2012 09:40 AM
521 heads,intake,and cam advice Redhawk Engine Tech 12 01-15-2011 10:09 PM
521 Complete Eng / P-51 Heads 65Falcon The Auction Block 4 12-16-2010 01:12 PM
Carb Advice for 521, Power Estimation? Ron Earp Engine Tech 13 12-08-2010 09:12 AM
Inboard 521 build, cam advice force26 Engine Tech 1 01-19-2008 09:33 AM
