545ci Ford in a 2003 Cobra - 460 Ford Forum
 1Likes
  • 1 Post By showme cobra
post #1 of 14 (permalink) Old 03-30-2019, 09:20 PM Thread Starter
Finally starting my build 545ci, kaase p51 heads aprox 12:1 comp, want to put a T56 manual behind it but think the torque will kill it so an auto will go in, is there a hydraulic roller cam that's big enough to feed it or dont **** around and get a solid roller? car will be alot of street and an occasional nmra weekend
showme cobra is offline
post #2 of 14 (permalink) Old 03-30-2019, 09:22 PM Thread Starter
any tips on a 545ci?
post #3 of 14 (permalink) Old 03-30-2019, 09:29 PM
Quoted: 178 Post(s)
use a solid roller
BUY,SELL, or TRADE BBF parts
Dynoed or Test STAND RAN
CYLINDER HEAD PORTING
HEAD FLOWING
PRO SYSTEMS CARBS
BOSS 302 351 429 800CI+
BOSS 429 is offline
post #4 of 14 (permalink) Old 03-30-2019, 09:51 PM
Quoted: 210 Post(s)
Originally Posted by BOSS 429 View Post
use a solid roller
Rich, which lobes from comp do you like to use?
Cheers, Bob
bob460 is offline
post #5 of 14 (permalink) Old 03-30-2019, 09:54 PM
Quoted: 210 Post(s)
How much hp/tq you after?
What rpm you after?
Pump gas?
Cheers, Bob
bob460 is offline
post #6 of 14 (permalink) Old 03-30-2019, 10:59 PM Thread Starter
would like to see 800 hp and 750 to, race gas hopefully probably produce a little more but with 12.1 compression it would need race gas, what compression can you get by with on pump gas? and if you go with a big roller cam it will want high compression correct?, appreciate everyone's input, built some Cleveland's back in the 80's.
post #7 of 14 (permalink) Old 03-31-2019, 02:03 PM
I’d think that a Magnum T56 should live behind your 545 (I’ve got a Magnum to go behind my AFR headed 545) but consistency on the drag strip would suffer. As for street driving a C6 would mean a higher cruise RPM with no overdrive so that’s something to consider also.
wickettoby1 is offline
post #8 of 14 (permalink) Old 03-31-2019, 06:03 PM
Quoted: 210 Post(s)
With the right cam and combo 12.1 will run on pump gas, give KAASE a call he will set you in the right direction.
800hp in a cobra will be a handfull, but sure will be fun.
Cheers, Bob
bob460 is offline
post #9 of 14 (permalink) Old 04-01-2019, 12:32 AM Thread Starter
Thanks bud, will do. with my cobra engine had aprox 4500 invested in heads and cams so 2600 is refreshi
post #10 of 14 (permalink) Old 04-03-2019, 03:28 PM
Zac
If you have e85 readily available in your area, run some compression and feed it e85. It's much cheaper than 100+ octane jug or barreled fuel.
I built a 13.x:1 408 Windsor and run e85 in it with no problems through a Holley Terminator throttle body setup.
The two downsides to e85 I have found is the blend consistencies are checkered depending on the station/pump and the lack of thermal energy in it means you gotta burn more of it to go the same distance. (And the funky smell...I guess that's a third downside, depending on one's perspective)
I would run a 4L80e in the car. Heavy? Yes, but durable and adds a lock-up converter and overdrive that the c6 doesn't have. I have built many 4L80s and they are excellent units.
Zac is offline
post #11 of 14 (permalink) Old 04-03-2019, 05:18 PM
rattle_snake's Avatar
Can't offer any advice, but why a BBF over the S/C 4.6l in a Terminator?
800hp is easy with a stock 4.6. Just add bigger blower of choice and a few supporting mods. Did you get the car with no motor/blown up motor?
Justin
72 F250
14 F250 6.7, CCLB, 37s
04 Mustang Cobra, 14psi + N20
rattle_snake is offline
post #12 of 14 (permalink) Old 04-05-2019, 08:17 AM
Your combo sounds good . I have a552 built by Jet Boat Bob with P51 heads Ford SVT block a Lem Evans Custom Comp cam. Heads were flowed by Charlie Evans and flowed 411 cam 728 lift , ford intake . Dyno at Autimotive Machine & Performance in KY. Hp 752.6 @6200 torque 717 on race fuel , forgot to mention 10.1 compression on a 2 bbl carb !!!!!!!!!!!!! No just kidding on the 2 bbl a dominator 1150 and no NOS. When I called Lem up I told him I wanted a engine combo with the P51 heads and big HP but wanted to run on pump gas !! He laughed at me !!😂😂😂 I told him I was serious that I was building a 1966 Pro Street Fairlane and wanted 700 HP on pump gas . We got with Bob ( he laughed too) but built this combo which I can run 50- 50 93/and race gas. My car should be finished by the end of year, can’t wait to turn that Beast loose !! Good luck with your build
PROSTREET66 is offline
post #13 of 14 (permalink) Old 04-05-2019, 12:00 PM
cletus66's Avatar
Quoted: 27 Post(s)
Originally Posted by PROSTREET66 View Post
Your combo sounds good . I have a552 built by Jet Boat Bob with P51 heads Ford SVT block a Lem Evans Custom Comp cam. Heads were flowed by Charlie Evans and flowed 411 cam 728 lift , ford intake . Dyno at Autimotive Machine & Performance in KY. Hp 752.6 @6200 torque 717 on race fuel , forgot to mention 10.1 compression on a 2 bbl carb !!!!!!!!!!!!! No just kidding on the 2 bbl a dominator 1150 and no NOS. When I called Lem up I told him I wanted a engine combo with the P51 heads and big HP but wanted to run on pump gas !! He laughed at me !!😂😂😂 I told him I was serious that I was building a 1966 Pro Street Fairlane and wanted 700 HP on pump gas . We got with Bob ( he laughed too) but built this combo which I can run 50- 50 93/and race gas. My car should be finished by the end of year, canít wait to turn that Beast loose !! Good luck with your build
I'm building a similar combo with similar goals. What do you mean by this? I will have 10.1:1 compression with ported SCJ heads and want to run on straight 93 octane.
cletus66 is offline
post #14 of 14 (permalink) Old 04-06-2019, 08:41 PM Thread Starter
Thanks guys, I have done the 4 valve cobra motor with small to large superchargers and was in the process of putting a Bullseye 83mm on it when hit a financial problem and sold the engine and drivetrain out of it, been sitting on jackstands for 2 yrs
so I'm doing something different now and excited about big cubes
1EFF100 likes this.
1993 Teal Cobra 545ci carbedcobra93 The Auction Block 9 09-01-2011 12:57 PM
1993 cobra 545ci carbedcobra93 Car Buildup Forum 10 07-14-2011 09:22 AM
2003 Cobra, Stroker, Kenne Bell 64T-bolt The Auction Block 0 10-12-2010 07:35 AM
2003 Cobra (Black) coolhandluke521 The Auction Block 4 04-09-2009 09:37 AM
TRADE 1963 1/2 Galaxie 500XL w/ 514 crate for 2003-04 Cobra 63XL514 The Auction Block 5 08-20-2008 08:13 PM
