MSD ready to run and 6AL questions - 460 Ford Forum
post #1 of 8 (permalink) Old 04-04-2019, 05:59 AM Thread Starter
amthatiam's Avatar
I just got a really good deal on a little used MSD 8350 ready to run distributor and a 6AL box, my question is are the two compatible? How does one make the two play together? Is their a harness that makes a clean connection between the two? Should I just run the distributor and sell the box, or, should I sell the distributor and get the 8477 pro billet? Thanks in advance for your help.
Dan
71 Lincoln MKIII Sincity
A thing of beauty, a work in progress
amthatiam is online now
post #2 of 8 (permalink) Old 04-04-2019, 07:33 AM
Paintdudeluke's Avatar
google the wiring diagram for those and you'll find it all laid out.
Paintdudeluke is offline
post #3 of 8 (permalink) Old 04-04-2019, 08:03 AM
Quoted: 72 Post(s)
If it is ready to run it does not require a box. If you want to run the 6AL you'll have to use another dist.
B F Evans Race Parts
270-278-2376
Lem Evans is offline
post #4 of 8 (permalink) Old 04-05-2019, 04:19 AM
Quoted: 41 Post(s)
You can use it no probs . Use the RTR as is , hook it to the 6AL box and trigger via the white wire .
If the RTR module does play up you can put in a normal pickup and then hook to the 6AL via the mag pickup
gregaust is offline
post #5 of 8 (permalink) Old 04-05-2019, 05:30 AM Thread Starter
amthatiam's Avatar
Thanks for the replys,
I like simple so the RTR appeals, one less thing to have to test if the spark goes out, less wiring and complication under the hood. The plan for the engine is AFR headed street only 466/72 or 521 (told Scotty I'd decide which soon) 600 H.P. +/_ Do I really need the box for the street? If it is recomended I'll sell the distributor and get the pro billet, if it isn't really needed I'll keep the RTR and sell the box use the money elsewhere....
Dan
post #6 of 8 (permalink) Old 04-05-2019, 12:26 PM
Quoted: 495 Post(s)
Dan
Use the multi spark CD box.
Much better idle and low speed transition.
Sell your ready to run and get a distributor with mag pick up and vacuum advance.
SJ
used 2b RHP
post #7 of 8 (permalink) Old 04-05-2019, 01:10 PM Thread Starter
amthatiam's Avatar
SJ
used 2b RHP
That's settled, I have the RTR distributor listed in the for sale section if anyone is interested, my email is listed and I'll consider offers. Thanks.
Dan
post #8 of 8 (permalink) Old 04-05-2019, 07:07 PM
Just an FYI, anyone considering buying a 6AL, look at the intellitronix box. Not only is it under $200, its better insulated more like a marine unit, has the exact features as the 6AL, plus it has a nice harness with plugs at the box. Best part is that its made in Ohio and has a LIFETIME warranty from the manufacturer. I run one and its great. https://www.ebay.com/itm/MSD-6AL-rep...72.m2749.l2649
MSD 6al, MSD Starter Saver, MSD Two Step, Msd RPM Activated Switch Onequik76 The Auction Block 8 02-20-2015 06:56 PM
MSD 6AL and rpm selector msd 8670 madmulberry The Auction Block 2 10-12-2011 09:36 PM
WTB MSD 6AL and 8580 MSD distibutor dbeers02 The Auction Block 0 12-20-2010 04:30 PM
Used MSD blaster3 and MSD 6al 65comet404 The Auction Block 6 10-11-2010 02:42 PM
MSD 6AL or 6AL-2 gregaust Engine Tech 1 04-01-2009 05:10 AM
