Cam Timing - 460 Ford Forum
 3Likes
  • 3 Post By The Mad Porter
post #1 of 4 (permalink) Old 04-06-2019, 02:17 PM Thread Starter
Cam Timing
I have an 1987 460 in my 79 F350 4x4. I plan on rebuilding the 460 soon doing a stock rebuild except for cam timing. How would moving the timing from 8 deg. retarded to straight up effect the power curve ? Looking for low end torque. Also truck has to pass Calif. smog. Thanks
1979F350 is offline
post #2 of 4 (permalink) Old 04-06-2019, 04:28 PM
Quoted: 503 Post(s)
Straight up cam timing will not cause a fail for Cali smog
Use the 612 EFI pistons at 0 deck for higher 8's static c/r
207 / 219 voodoo cam on a 112
Properly curved duraspark distributor
Factory carb
The above has already and will pass cali smog.
The Mad Porter is online now
post #3 of 4 (permalink) Old 04-07-2019, 03:17 PM Thread Starter
612 EFI pistons ? are those Sealed Power H612CP20 cast pistons ?
1979F350 is offline
post #4 of 4 (permalink) Old 04-08-2019, 12:00 PM
Quoted: 503 Post(s)
H612cp sealed power pistons yes.
2mm
2mm
4mm ring package.
Use a moly faced ring package.
SJ
used 2b RHP
Could not get valve timing at cam spec while degreeing cam 4604X4 Engine Tech 10 03-06-2017 01:50 PM
Will 400 timing gears work if I retard the timing? EVAN Engine Tech 12 02-13-2010 04:49 PM
509ci cam selection and cam timing C-bank Engine Tech 7 03-08-2009 06:28 PM
cam timing 514 crate motor or sugestions for a better cam rat poison Engine Tech 13 01-15-2009 08:46 PM
Front Dipstick Tube OEM Timing Covers & Timing Pointers Paul Kane The Auction Block 4 04-30-2007 10:42 AM
