Best way to remove old head gaskets - 460 Ford Forum
post #1 of 3 (permalink) Old 04-18-2019, 06:34 PM Thread Starter
What is the best way to clean the old head gasket from the heads and the block? Break cleaner, scotch brite and patience?
1979_F100 is offline
post #2 of 3 (permalink) Old 04-18-2019, 07:02 PM
Quoted: 24 Post(s)
I start with an old school gasket scraper and finish up with a new/flat coarse wet stone and mineral spirits. The wet stone also works on exhaust ports and exhaust manifolds, or any gasket surface.
Richard
RLS7201 is offline
post #3 of 3 (permalink) Old 05-14-2019, 02:14 PM
away's Avatar
https://www.460ford.com/forum/attach...1&d=1557861258
Attach this to an angle grinder and you are all set. You can buy these at Lowes.
572CI 1978 Mustang Cobra II-Ron's Terminator-Alky Injection
532CI 1972 Maverick-Ron's Terminator-Alky Injection
2000 Excursion 7.3 Powerstroke "TS-6 position chip"
2001 F250 7.3 Powerstroke "TS-6 position chip"
away is offline
What's Best Way to Remove Cam Sprocket? audioresearch Engine Tech 3 07-10-2016 12:53 PM
Best Way to Remove Valve Cover Baffles,Where to buy Valve Cover Grommet? audioresearch Engine Tech 0 03-24-2016 12:53 PM
Best way to remove location pin from block deck? jones Engine Tech 5 04-21-2008 04:55 PM
Best way to remove decals/Vinyl graphics loganwildman Chilly's Garage 7 01-10-2008 07:57 AM
Best way to remove stuck onmetering block gasket material??? ProStreetFairlane Engine Tech 8 11-13-2007 05:03 PM
