crankshaft end play - 460 Ford Forum
post #1 of 4 (permalink) Old 04-23-2019, 11:20 AM Thread Starter
crankshaft end play
what is the recommended end play clearance for the thrust bearing.thanks.
jim
ford truck freak
fomocoloco is offline
post #2 of 4 (permalink) Old 04-23-2019, 12:38 PM
Quoted: 499 Post(s)
jim
We typically set thrust at .005" to .006"
SJ
used 2b RHP
post #3 of 4 (permalink) Old 04-24-2019, 07:07 PM
Quoted: 72 Post(s)
.005"-.006" will support a lot of HP for sure.
B F Evans Race Parts
270-278-2376
Lem Evans is offline
post #4 of 4 (permalink) Old 04-25-2019, 10:28 AM Thread Starter
Red face
thanks. i have about .020 deck clearance on a 73block with JE .040 pistons and a 4.30 stroke. all 4 corners are within a thou or 2. should i deck the block .020 or go for the .015 or leave the deck as is and go for thinner head gaskets. thanks.
jim
ford truck freak
crankshaft end play thermod Engine Tech 10 12-14-2015 02:47 PM
Crankshaft end play loman Engine Tech 3 01-22-2013 05:02 PM
crankshaft end play thrust bearing spec???/ sskwb Engine Tech 2 07-11-2010 12:50 PM
Crankshaft end play specs? dually04 Engine Tech 5 07-18-2009 03:25 PM
Camshaft end play spec? junkdude Engine Tech 1 05-10-2007 04:50 PM
