Fast twitching vacuum reading on my engine... - 460 Ford Forum
post #1 of 4 (permalink) Old 05-15-2019, 11:08 PM Thread Starter
Hi,
I have a '69 429, with a stock block, heads and internals. This is the K-code (2bbl 10.5:1) engine. I am running the Weiand stealth intake, with a MSD Atomic throttle body. I have a fast twitching vacuum reading (twitching from 18 to 18-3/4) This is happening at idle and at higher rpm. A compression test showed 175-185lbs at cranking across all cylinders.
When I got the car I had two bent push rods and one of the valves were frozen shut. I had to soak that for a couple of days to get it running freely.
Video of the vacuum gauge/test. https://youtu.be/4PzHeXErJ78
Any thoughts/ideas?
Thanks,
Mark
D-train is offline
post #2 of 4 (permalink) Old 05-16-2019, 08:27 AM
Quoted: 97 Post(s)
Looks good to me.
thermod is offline
post #3 of 4 (permalink) Old 05-16-2019, 01:04 PM
Quoted: 499 Post(s)
Reading should be rock steady however given the age and condition you could have weak valve springs / sticky valve(s) or a valve that is not seating completely. Not the end of the world.
Take a look here:
https://www.gregsengine.com/using-a-vacuum-gauge.html
SJ
used 2b RHP
post #4 of 4 (permalink) Old 05-17-2019, 11:24 PM Thread Starter
I was thinking weak valve springs ( I thought that I put that in the initial post, but apparently not) I was going to run a leakdown test and see if I am getting anything past the valves. I wanted to get thru this summer season with a cleaner exhaust... If I replace the springs, can I go with the Melling VS840's ? ...or the Sealed Power VS703's?
Thanks!
Mark
D-train is offline
Star Vacuum Pump Vacuum Question? MrScharfenberger Engine Tech 3 12-18-2014 12:24 PM
Vacuum advance using manifold vacuum Hangman Engine Tech 12 09-06-2014 01:00 PM
Electric Vacuum Pump with a Vacuum Reservior? xoliex Car Buildup Forum 3 11-20-2013 06:41 AM
Vacuum Reading cgray Engine Tech 0 02-28-2013 08:46 PM
Need help fast real fast Northwest outlaw Engine Tech 11 07-10-2008 10:27 PM
