Distributor 460\429 - 460 Ford Forum
 2Likes
  • 2 Post By BOSS 429
post #1 of 10 (permalink) Old 05-24-2019, 01:48 PM Thread Starter
Quoted: 6 Post(s)
Distributor 460\429
Looking for a good Distributor for my ford 429. Most recommend the HEI Electronic Distributor but in 50k, 60K, 65K. Does it matter that much which one to choose. Here are some random recommendations I've gotten:
Pro Billet Distributor Wpm-6606-bl
Cardone 84-2813 Single Vacuum
PerTronix D332710 Billet Mag Trigger Distributor
PROFORM 66969B HEI Pro Series
Scott Drake IGN-D1352 HEI
Speedmaster PCE376-1044, PCE376-1182, PCE376-1047
Kurthansen193 is offline
post #2 of 10 (permalink) Old 05-24-2019, 02:53 PM
Quoted: 8 Post(s)
I went with a MSD ready to run distributor and blaster coil. Looks nice and its a 3 wire setup then timing.
OneAmongOthers is offline
post #3 of 10 (permalink) Old 05-24-2019, 02:54 PM
Quoted: 184 Post(s)
install a pertronix in your dist, or buy a msd
you could also convert to dur a spark ford, but that takes a box, as does the msd
pertronix is the simplest
BUY,SELL, or TRADE BBF parts
Dynoed or Test STAND RAN
CYLINDER HEAD PORTING
HEAD FLOWING
PRO SYSTEMS CARBS
BOSS 302 351 429 800CI+
BOSS 429 is offline
post #4 of 10 (permalink) Old 05-24-2019, 08:11 PM
Quoted: 8 Post(s)
If you do get a new distributor be careful removing the old one. When I pulled the old one out of my engine the oil pump pickup shaft came with it.
post #5 of 10 (permalink) Old 05-25-2019, 10:24 AM
John F.'s Avatar
Quoted: 19 Post(s)
Better than having fall into pan like my FE did to me.
1956 Ford F100...466/C6, Edelbrock aluminum heads and Preformer intake w/750cfm carb, Comp. cam , H/S roller rockers, MSD lighter, KB flat top pistons, Currie rear end, B & M shifter, tubbed, Ididit column
John F. is offline
post #6 of 10 (permalink) Old 05-25-2019, 12:33 PM
Quoted: 8 Post(s)
Well that sucks.
post #7 of 10 (permalink) Old 05-27-2019, 10:32 PM Thread Starter
Quoted: 6 Post(s)
One recommendation was to replace the stock HEI ignition with an MSD ignition box, coil, and billet distributor
post #8 of 10 (permalink) Old 05-27-2019, 11:20 PM Thread Starter
Quoted: 6 Post(s)
Anyone try this A-Team Performance HEI Complete Distributor 65K Coil Compatible with BBF Big Block Ford. Will it still require an ignition
post #9 of 10 (permalink) Old 05-28-2019, 10:05 AM
Quoted: 184 Post(s)
why/ cause its cheaper?
msd,duraspark,and pertonix are all a proven product. and can be bought over the counter at many diff places
The Mad Porter and jeffgfg like this.
HEAD FLOWING
PRO SYSTEMS CARBS
BOSS 429 is offline
post #10 of 10 (permalink) Old 05-28-2019, 06:00 PM
Talk to Scotty at Parkland in Tacoma. He will custom curve a duraspark for you based on a conversation with you about the rig and your expectations. Very knowledgeable.
His handle on here is "The Mad Porter"
r72cnvt is offline
F/S: MSD Pro Billet #8577 distributor for 351c/400/429/460 F100cleveland The Auction Block 4 01-12-2009 07:05 PM
MSD Distributor for 351C/M, 400, 429-460 wildstang The Auction Block 0 12-06-2007 12:18 PM
wanted: 429/460 tunnelram & small msd distributor fordmaniack The Auction Block 5 07-31-2007 08:04 PM
Wanted: Bronze Distributor Gear For A MSD 460 Distributor rvesterby The Auction Block 1 05-18-2007 08:22 AM
Wanted Ford 429/460 Distributor Cores c.evans The Auction Block 21 12-31-2006 05:19 PM
